Dislikes: 0
Cleaning Rubber Boots in Door Jambs
I was disappointed that I couldn't get these areas any cleaner.
Used Optimum Power Clean followed by CG Citrus Wash & Clear with a Wheel Woolie.
I was able to determine that the light areas that look dirty area actually areas with NO base coat on them. The light color you see is primer.
What are you using to clean the OEM coating off of the rubber boots?
In my photo they are labeled Door and Body.
I scrubbed and scrubbed with OPC and IPA on the Door boot with OK results, but took too long.
Body door boot was cleaned less aggressively.
Both were dressed with 1Z Gummi.
Super Member
Re: Cleaning Rubber Boots in Door Jambs
I would think that the large wheel woolie brush would not be the best choice into getting inside small cracks and crevices.
These might be better choices.
The Wheel Woolies Boar's Hair Detailing Brush, 1.25 Inch
Wheel Woolies Boar’s Hair Detail Brush 1 inch
You can get that brush or just head down to Home Depot and see what brushes they have.
or something like this
Lug Nut Brush,Clean Wheel Brush,clean brake calipers, clean lug nuts, boar's hair wheel brush, best wheel brush, wheel lug nuts
Super Member
Steam if you have it would prolly do wonders in there
"Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"... aim4squirrels
Super Member
I also use brushes for that application. I have several for different purposes and i have cut the bristles down on some so they are shorter and thus a little stiffer for some areas. Plus i'm not too concerned about scratching a rubber grommet or boot.
Super Member
"Be wary of the man who urges an action in which he himself incurs no risk."
~Joaquin de Setanti
Junior Member
This is the method to start with and works most of the time(steam).Keep handy small wooly or boars hair and small bucket of water/apc mix if needed.After treating areas with APC/water mix blast with steam.Turns out excellent.
Originally Posted by FUNX725
Are you talking about the "yellowish" looking areas,
like what's on the "body-boot"?
Kinda looks like some left over cosmoline,
or moly-grease, from my viewpoint.
Cosmoline Remover just may do the trick.
Prima has their version:
Prima Cosmonot Cosmoline Remover, Prima cosmoline cleaner
Great tip.
Thanks Bob
Prima Cosmonot Cosmoline Remover, Prima cosmoline cleaner Added to CART
Use GG Rubber Prep.........not the cleaner.
Similar Threads
By Maxreed241 in forum Auto Detailing 101
Last Post: 02-03-2018, 09:51 AM
By matryx in forum Auto Detailing 101
Last Post: 04-07-2013, 08:43 PM
By spardavr4 in forum Auto Detailing 101
Last Post: 06-22-2012, 02:11 PM
By 02blackout in forum Ask your detailing questions!
Last Post: 01-26-2010, 04:07 PM
By VF-x in forum Auto Detailing 101
Last Post: 08-07-2008, 06:39 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
26 | 27 | 28 | 29 | 30 | 31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
