Dislikes: 0
Which pad for Optimum Hyper Compound?
I just ordered some Optimum Hyper Compound. I have Chemical Guys Hex pads in Yellow, Orange and Black. Do I need any special pads for the hyper compound?
I read somewhere that LC Hydro Tech pads work best with these new generation compounds and polishes. Is that true?
Regular Member
Re: Which pad for Optimum Hyper Compound?
what did you think of the hyper compound?
Super Member
According the Optimum:
"Optimum Hyper Compound can be used at any speed on your polisher and with a wool or foam pad. When using a wool buffing pad, the compound will remove 1000 sand scratches and lighter at 1000-1400 RPM. Faster buffing speed is not needed with this product. When using a medium or heavy cut foam pad, the compound will remove 1500 sand scratches and lighter at 1000-1400 RPM. The compound works more or less aggressively depending on the pad you choose."
Super Member
I have used the Optimum with various pads from 3M, Hexlogic, MF and Serious Performance and they worked perfectly with all of them. The Hydro pads do seem to be popular although I have not tried them
Thanks Guys. After much deliberation, I ordered the Optimum MF Cutting Pads. Will post a review of the pads and the compound soon. If the combination is really what it claims to be(Spray-able Compound, No dust, easy to wipe off, Can increase or decrease the cut based on the pad) I will be very pleased.
Curious as to what machine you have? Also, based on that, how the combination works out for you.
I have a Dewalt Rotary.
Thanks. Looking forward to your result pics.
Super Member
I love the OHC with their MF cutting pads - 5.5" on the PC speed 4.5 works amazing.
Thanks. That is very re-assuring. Is it correct to say that the MF cutting pads will have the highest possible cut, only exceeded by a wool pad? I think MF pads cut more than any foam pad.
Similar Threads
By Harry Da Hamster in forum Auto Detailing 101
Last Post: 11-16-2018, 02:58 PM
By ct18 in forum Customer Comments
Last Post: 12-21-2014, 02:06 AM
By Mister B in forum Show N' Shine
Last Post: 12-31-2010, 12:08 AM
By Anthony Orosco in forum New Car Care Products
Last Post: 04-25-2010, 04:42 PM
By O.C.Detailing in forum Ask your detailing questions!
Last Post: 10-17-2009, 10:31 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
26 | 27 | 28 | 29 | 30 | 31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
