Gurge
- Aug 26, 2010
- 521
- 1
looking for some rotary pad recommendations for 1 step clean / polish / wax on marine gelcoat (fishing boats)
i've got the 3m marine restorer & wax on the way, plus a handful of other light duty AIO products if needed.
I already have pretty much the full line of large 3m wool & foam pads available (thanks to taking care of my local kemperle rep). also a large ccs orange & white on hand if necessary
I plan to do a test spot before I go at it. Just seeing what the thoughts are here.
my initial thought would be the 3m superbuff wool but it may be too aggressive? the AG description for the 3m marine restore wax mentions foam pads. in which case i'd be thinking the 3m white compounding foam (egg crate style)
was hoping to get some input from experience. thanks
Edit: done plenty of boats in the past. Mostly with the DA. The rotary work I have done has been a dedicated step for compounding then polishing then waxing. which obviously takes a very long time. I'm comfortable with my pad choices in that department
