15% off sale & 3D AAT Products on sale!!
Elliot@Autogeek
*15% Off Coupon Code 3D15 valid on in stock items. Not applicable on previously placed orders, custom or special order items, extractors, air compressors, BUY ONE GET ONE, VIP Special, car covers, polishers & polisher kits, vacuums, Kreepstool, FlatStoppers, Shop Air Heavy Duty Drum Fans, vapor steamers, garage flooring, gift certificates, bulk and case pricing, complete wash systems or any item as noted on product page. One coupon code per order.
*Free shipping applies to orders over $50 with ground service within the 48 contiguous United States ONLY. Regular shipping charges apply to garage flooring and mats, air compressors, and carpet extractors as noted on those products. Regular expedited and international charges apply.
New Product Spotlight:
3D AAT 505 Correction Glaze
The all-in-one formula that corrects and protects!
[TD="align: center"]
[/TD]
[TD="align: center"] 3D AAT 505 Correction Glaze is an all-in-one product that will remove light swirls and scratches from your paint, while also using the power of Montan wax to protect against UV rays. 3D AAT 505 Correction Glaze is body-shop safe and is engineered for both fresh and cured paints. 3D AAT 505 Correction Glaze is designed to restore the luster of older paint, clear coat, or gel coated surfaces by providing a deep, wet gloss finish.
The path to perfect paint typically starts with a 3 step correction system. First step for cutting - removing swirls, scratches, and oxidation, second step for polishing - removing those finer swirls and cleaning up any leftover imperfections from step one, and finally, the third finishing step - for further perfecting the surface and imparting a high shine. But what if all three of those steps could be combined?
[/TD]
[TD="align: center"] We've seen many all in one products on the detailing market - but how many are body shop safe? 3D AAT 505 Correction Glaze is! Containing no silicon, only Montan wax which is body shop safe, 3D AAT 505 Correction Glaze is perfectly safe for use on both freshly painted and fully cured vehicles. [/TD]
[/TD]
[/TD]
[/TD]
[TD="align: center"] Before using 3D 505 AAT Correction Glaze.. [/TD]
[TD="align: center"] ..and after! [/TD]
3D AAT 505 Correction Glaze can be used on its own, or as a follow up product to a heavier cutting compound, and has the ability to remove light swirls and scratches, while also finishing the paint to a high shine. Manufactured with Montan Wax for the ultimate in UV protection, 3D AAT 505 Correction Glaze leaves your paint with a deep, wet gloss finish.
Directions for use:
1. Shake well before use. 3D AAT 505 Correction Glaze can be used with either a Dual Action or Rotary polisher.
2. Apply 4 to 6 pea sized drops of 3D AAT 505 Correction Glaze to a polishing or finishing pad.
3. Use slow back and forth overlapping passes to correct defects and apply protection.
4. Remove haze using clean, dry microfiber towel and buff off excess product by hand to get a deep, high gloss finish.
3D AAT 505 Correction Glaze 32 oz.
Retail Value: $69.99
Sale Price: $59.50
You Save $10.49 (15%)
3D AAT Paint Perfecting Combo
Retail Value: $131.94
Sale Price: $99.99
You Save $31.95 (24%)
3D Professional Detailing Products ON SALE NOW!
