Elliot@Autogeek
- Apr 24, 2017
- 362
*15% Off Coupon Code COVER15 valid on in stock items. Not applicable on previously placed orders, RUPES Polisher and polisher kits, single Griot's Garage polisher units, Vapor Chief Vapor Steamers, and gift certificates. One coupon code per order.
*$6.95 Flat Rate Shipping applies to orders with ground service within the 48 contiguous United States. Regular shipping charges apply to garage flooring and mats, air compressors, and carpet extractors as noted on those products. Regular expedited charges apply.
A car is a big investment; for many, the biggest investment you'll make besides a home.
As much as we would like to baby our cars and make sure they're never exposed to harmful conditions, that just isn't practical;
especially if you live in a cold climate in the winter.
While having our cars in a bubble isn't something that is going to work, protecting them with a cover made specifically for that purpose certainly will! Covercraft makes a wide selection of car covers to help you do just that.
If you don't have access to a garage or covered area to park in during the winter, you've probably come out to a snow covered car many times.
Now begins the de-snowing process - trudging through sometimes knee deep snow, getting out your handy-dandy SNOBruM and Ice-MasterIce Scraper to get your car road ready for your daily commute. You could cut this entire process in half if your car had been protected from the snow overnight!
Many drivers spend countless hours applying waxes and protectants to their vehicles, but they overlook the most obvious solution:
Cover it!
A car cover will not only protect the vehicle itself, it will preserve all the fine detailing you put into your vehicle.
[TR]
[TD]
COVERCRAFT TECHNOLOGY:
Covercraft has been protecting vehicles since 1965. Today they offer over 55,000 patterns to custom fit virtually any vehicle ever made. Since each pattern is based on the exact measurements of a given vehicle, you can be sure that your custom-made car cover will fit your vehicle.
[/TD]Covercraft has been protecting vehicles since 1965. Today they offer over 55,000 patterns to custom fit virtually any vehicle ever made. Since each pattern is based on the exact measurements of a given vehicle, you can be sure that your custom-made car cover will fit your vehicle.
[/TR]
[/TABLE]
In addition to patterns, Covercraft currently offers 12 different fabrics.
Each one is designed to meet your specific needs, no matter where you live and how often you drive your vehicle.
The fabrics are listed below.
Who Should Use A Car Cover?
Everyone! You don't have to drive an expensive or collectible car to own a car cover. Car covers are a practical way to protect any vehicle.Many of Covercraft's fabrics are lightweight and some can even be washed in your washing machine at home! They are not cumbersome or difficult to care for.
Covercraft features many different styles and fabrics, but these are our favorites for the ultimate in winter protection:
[TR]
[TD="align: center"]
Rate a 5/5 on the Covercraft Snowflake Scale - the highest snow protection you can get!
WeatherShield HD provides optimum protection. Everything about this cover says strength and unmatched durability. WeatherShield HD not only provides UV opacity, it repels snow, water, blocks dust, tree sap and bird droppings, and is still breathable to allow moisture and heat to escape from under the cover.
The base material for WeatherShield HD is woven by Glen Raven Mills (makers of Sunbrella®), using solution dyed UV resistant polyester fibers (see insert below to learn why solution dyed fabrics are better - courtesy of Glen Raven Mills). Not only is the fabric solution dyed, the 300 denier construction is 40% heavier than regular WeatherShield and the heavier denier thread provides double the tear and tensile strength.[/TD]
[/TR]
[/TABLE]
1. Maximum Weatherproof
2. Superior Dry Time
3. Breathable
4. Maximum UV Resistant
5. Dust Proof
6. Reinforced, non-scratch grommets
RECOMMENDED USE:
If you are storing your vehicle outdoors for extended periods, WeatherShield HD is the best choice.
It is superior to all other fabrics for intense sun climates (like Florida), coastal areas, and in northern climates that see a lot of snow.
Use the WeatherShield HD in dry, dusty climates or rainy ones.
It’s the best all-around outdoor protection offered by Covercraft.
[TABLE="align: center"]If you are storing your vehicle outdoors for extended periods, WeatherShield HD is the best choice.
[TR]
The most water-resistant, yet breathable, barrier fabric money can buy.
[/TD]
[/TR]
[/TABLE]
CoverCraft has created NOAH, using the newest, state-of-the-art production technology.
Three high-tech materials are ultrasonically bonded. The protective outer layer is a bi-component created for strength and softness.
A silver-gray color was selected for its heat-resistant properties. The fabric is also treated with UV inhibitors for extended outdoor use. The middle layer is micro-porous breathable film with holes that are smaller than droplets of water or dust, yet large enough to allow moisture vapor to escape.
The NOAH Car Cover features:Three high-tech materials are ultrasonically bonded. The protective outer layer is a bi-component created for strength and softness.
1. Protective Outer Layer
2. Micro-Porous Middle Layer
3. Soft, Paint-Protecting Inner Layer
4. Double stitched overlapped seams
5. Neoprene elastic hems
RECOMMENDED USE:
As its name implies, NOAH fabric is the most water resistant of all of CoverCraft fabrics.
It is a great outdoor cover, particularly in areas prone to wet weather.
Use it for occasional or long-term, outdoor or indoor storage.
Lightweight sun, dust, and snow protection!
Covercraft's Reflec'tect car cover fabric offers excellent UV protection in a light, easy to handle car cover.
The fabric is water-resistant and repels dirt and dust. Keep your vehicle clean and cool when it's parked.
The Reflec'tect car cover is convenient enough to use every day.
Take it off, fold it up, and stow it in the trunk.
The Reflec'tect car cover is made of UV-reflective silver, woven fabric that reflects UV rays to keep the vehicle cooler.
The cover is mildew resistant and breathable to allow any moisture to escape from underneath the cover.
That, combined with the cover's soft touch, make the Reflec'tect car cover a great choice for all seasons.
The Reflec'tect Car Cover features:As its name implies, NOAH fabric is the most water resistant of all of CoverCraft fabrics.
1. Moisture Resistance
2. Breathable
3. Dust / Pollution Barrier
RECOMMENDED USE:
The Reflec'tect car cover is good for indoor or outdoor car storage.
The reflective silver finish reflects sunlight to keep the vehicle cooler when stored outside.
The cover is dust-resistant, making it perfect for indoor storage as well.
Use the cover daily to keep the vehicle cleaner and cooler.
While those are OUR top Winter picks by CoverCraft, be sure to check out the full line up and find out what works for you!
Covercraft,covercraft Car Covers, custom car covers, noah car covers, weathershield car cover, block it car covers
BLACKFIRE Car Cover Prep Kit
Our Price: $40.96
Sale price: $25.00
