1973 Pantera
1973 Pantera
Here's some pictures of a 1973 I took at Gweed's Gangster's Car Show last Tuesday night, I've invited the owner to bring it to Autogeek's Show Car Garage for a show car makeover, no word from the owner yet...
I've incredibly nice...
The paint actually looks really good on this car unlike so many we all see at car shows but there's always either a little room for improvement and/or there's nothing wrong with refreshing an already show car finish like described here,
What condition is the paint on your vehicles?
Using the guide below, inspect the paint on your car or cars, trucks, SUVs, etc. And then post which category you think each vehicle matches.
Show Car Quality
Paint in this condition is as perfect as it can be in any lighting condition. The only defects you should see are fingerprints, smudges or light dust on what otherwise appears to be a flawless show car finish.
The finish on a car in this category can hold up to close scrutiny under bright lights by the most discerning eyes.
The paint in this category has been put through a series of machine polishing procedures to maximize D.O.I, gloss, clarity, depth, reflection, richness of color, shine and even slickness.
If needed, the paint has been sanded, cut and buffed to remove orange peel and any other surface texture to create a 100% flat surface to maximize D.O.I.
RIDS have been removed to the extent that it is safe to do so without compromising the top coat. Paint is meticulously cared for on an as needed basis to ensure that it is always display ready.
Excellent Condition
The paint in this category looks factory new or better than factory new.
The paint looks like it has been professionally machine polished and sealed with a wax, paint sealant or coating and is regularly maintained.
When viewed in bright sunlight, the paint looks excellent, that is there are few or no visible swirls or scratches or so few that there's not enough of them to require machine polishing.
The paint has few or no swirls, scratches or any other visible paint defects outside of RIDS.
Good Condition
Light swirls, scratches, water spots and oxidation.
When viewed in bright sunlight, the paint should look pretty good overall except that it has light or shallow looking cobweb swirls and scratches throughout the paint. Any water spot problems should be shallow imprint type stains common to Type I Water Spots, certainly not deep craters like Type II or Type III where the paint is physically stained.
Paint in this condition would require one or two polishing steps before a finishing wax could be applied to bring the quality to Excellent or Show Car Quality.
Mildly Neglected
Normal day-in, day-out wear-n-tear and minimal appearance maintenance outside of the occasional car wash. Paint in this condition has medium to light swirls, scratches, water spots and oxidation.
Cobweb Swirls and Scratches
When viewed in bright, overhead sunlight there are cobweb swirls and scratches evenly instilled throughout the entire finish but they're likely instilled through improper washing and drying techniques, which means the depth of these defects won't be as deep as the swirls and scratches in a severely neglected finish. The swirls are not inflicted by a rotary buffer. The remedy is still the same except you might be able to use a less aggressive pad or product.
Water Spots
Paint with Type I Water Spots or shallow Type II Water Spots that are more imprints than they are craters falls into this category.
Oxidation, Staining and Surface Impurities
If the car being evaluated is a daily driver, is parked outside 24/7 and has not been regularly polished and/or waxed for a few years then chances are good it has light oxidation and staining of the paint with some type of roadgrime or a build-up of impurities or some type of topical contamination that does not wash or wipe-off.​
Severely Neglected
Paint in this condition has deep swirls, scratches, water spots and oxidation. Paint in this condition has normal day-in, day-out wear-n-tear plus no real regular maintenance. Vehicles in this category are rarely washed on a regular basis and when they are washed they are washed improperly or taken through automatic car wash.
Paint that is severely neglected means that when viewed in bright, overhead sunlight, there are so many swirls and scratches that the paint has an overall hazy appearance which blocks your view of the true color.
Water Spots
Paint that is in the severely neglected category can have Type I, Type II and Type III water spots on all horizontal panels and even the vertical panels if caused by a sprinkler or some type of water spray.
Severe Oxidation
Paint in this category has oxidized to the point where the surface has a uniform dull appearance to the horizontal surfaces and to some extent the vertical panels. Clear coats do oxidize but usually slower than single stage paints and don't normally get the whitish, chalky appearance with a rough texture common to old, neglected single stage lacquers and enamels.​
Rotary Buffer Swirls
This category is primarily for cars that have been improperly buffed-out using a rotary buffer leaving the finish inflicted with rotary buffer swirls, holograms or buffer trails. (Whatever term you like, they all mean the same thing).
The severity of the swirls can range from shallow to deep depending upon the pad and product used with the rotary buffer as well as technique or lack thereof.
The normal three culprits for paint in this condition are,
DISO = Dealer Installed Swirl Option
BISO = Bodyshop Installed Swirl Option
HISO - Hack Detailer Installed Swirl Option​
Extreme Oxidation
Paint is this category is primarily associated with traditional single stage lacquer and enamel paints and normally found cars built before 1980. Extreme Oxidation means the paint has deteriorated to the point that it has a chalky, whitish appearance.
Paint in this category is typically antique or original. It can be a re-paint, but it would be an older re-repaint. Paint with extreme oxidation can be saved by carefully removing the dead, oxidized paint and rejuvenating with polishing oils the remaining paint. After polishing the color is restored and remains even when exposed to sunlight. If the color fades away then this is an indicator that the paint has become unstable.
Extreme Orange Peel
Paint in this category is primarily re-paints from body shops, dealerships or do-it-yourselfer garage paint jobs. It doesn't normally include factory orange peel because factory orange peel is a given for new cars and truck and due to how thin the top coat is on a factory paint job there's a certain amount of risk you have to accept if you choose to remove the factory orange peel while re-paints will tend to have enough material that the problem can be safely corrected via sanding and buffing.
Unstable
This category is for older, single stage paints that have been exposed to the sun for a long enough period of time that the pigments have become unstable. That is even if you remove the oxidation and gorge the paint with some type of polishing oils, any original color that is restored is only a temporary fix and when the paint is exposed to the sun or after a few days pass the color fades back to where it was before you started.
Clear Coat Failure
Clear coat failure is the point in which the top clear layer of paint has either de-laminated from the basecoat and is peeling off. Clear coat failure can also be when the clear layer of paint has deteriorated to the point where it's turning a whitish color in the beginning stages to full blown deterioration where it has turned white and is flaking off and the car look like it has a severe rash.
Past the point of no return
Paint in this condition will be a paint job that falls into one of the above categories but it is so far gone that nothing you pour out of a bottle or scoop out of a can from any company will fix it.
The Pantera was ahead of it's time and was quite a car for it's day. Back in the day, 1972, a friend of mine had a 1972 Pantera, light green metallic, and it was gorgeous!
Gorgeous car Mike!! :props:
that car is on my bucket list. Thanks for sharing Mike!
I have always liked the lines of the Pantera. :xyxthumbs:
Some Pantera Trivia......
1971 DE TOMASO
Pantera
Formerly owned by Elvis Presley
Engine type: overhead valve V-8 (Ford)
Engine size: 351 cubic inches
Horsepower: 266
Price when new: $9,000
Elvis Presley, who had a passion for both guns and cars, shot this Pantera with his personal firearm during a temperamental outburst when he lost his patience because the car would not start. The two bullet holes on the steering wheel rim and one on the floor pan were never repaired and today serve as reminders of his occasional fits of rage. Elvis bought this Pantera for $2,400 in 1974 for his girlfriend, actress Linda Thompson. Although its mid-engine configuration qualified it for “exotic car” status, the De Tomaso Pantera cost less than a comparable Ferrari or Lamborghini because of it relatively inexpensive, but still potent, Ford engine.
Collection of Margie and Robert E. Petersen
Petersen Automotive Museum
Randy
Such a neat car... that candy apple red paint looks amazing on those angles and curves.
My father used to own one. It was crazy fast in its day. Tim Horton died driving one of those. The left rear half shaft would snap on those and take all the brake lines, etc with it when it went.
Love the pantera, I got the privilege to help rebuild one at my dad's shop about 22 years ago, awesome experience (aside from the car catching fire on me and almost burning to the ground)
My best friend from back home had a tie when we were really little (around 8-9 year old time frame) and every once in a while when we needed to get dressed up he wore it. It had a whole bunch of pictures of cars on it (as even then, both he and I were obsessed with them), there were Ferrari's, Lamborgini's, I think even a porsche on there. There was also the Pantera, I remember him telling me about it, as I never heard of it before. One day several years later I saw one at a car show, The Hot Rod Super Nationals in Canfield, OH (used to be a big event, cruise, etc). That car will always have a fond memory in my heart and if I am ever able to have a 4th or 5th car, it will be one of them just for the memories and the attachment I have to that and my best friend from way back when we were little.
I remember seeing one of these in the showroom when they were making them, and trying to convince my father he should buy one, which of course went over like a lead balloon.
