HighEndDetail
- Apr 29, 2006
- 1,881
It only gets washed when it goes in for service
As you can see from the befores, that the paint is a little neglected. And it is a black single stage paint also.
He is the second owner, and drives it everywhere. It is his favorite car to drive. He has owned the car for about 10 years
The dashboard is cracked and ripped all over. And he won’t replace it.
The Wash
It was washed the day before, and part of it needed a little more. I used my apc/water mix to spray down the front end, and both lower rocker panels. And also the back bumper area.
The Gameplan
As I inspect the paint, I have found it is thin in some places. Since you could see the metal in places. So I take out the PC and go with XMT 360. I had to use the yellow edge pad.(my grn pad dropped into some dirty water on the ground).
That is why I like the XMT360 so much. It cleans the paint, helps correct it, and then seals it at the same time.
Extrior trim
Since it was in rough shape I went with Black wow.
This is what I had to work with. And remember it was washed too.
You can still see the embedded dirt near the license plate
Can you tell which side was done
The finished product
You can see the dash in this pic
