Hey,
My last order consisted of a can of 1Z Einszett Klima Kleaner. I just wanted to post my procedure and my results since people often have so many questions about this product.
First, a re-summary of the directions as stated on the back of the product:
1.) Shut off the HVAC entirely and shut the vehicle off.
2.) Slide the hose into one of the CENTER HVAC vents as far as it can go.
3.) Spray the entire can worth of product until it is empty. So yes, one can is good for only one application.
4.) Allow the foam product to clean the interior for at least 20 minutes.
5.) Open the doors and/or windows to vent out the scent during the cleaning process.
6.) Run the A/C for one minute after the cleaning process is complete.
7.) One application treats the HVAC for months.
Okay, now my procedure. First, a picture of the product as it is shipped by Autogeek:
Second, not yet mounting the hose onto the can, I carefully slid the hose as far down into my center HVAC vent as the hose would go:
I then removed the cap from the can and attached the head of the hose to the unit and pressed down. Soon after, I saw foam starting to come up from behind the vent. The Klima Kleaner releases the foam product slowly and smoothly so when the foam started coming up, I didn't panic or anything. I just removed the hose and slid it into the other center HVAC vent and pressed down again.
Finally, when it sounded like the can was running low on product, I decided to remove the hose again and slide it into the driver-side vent and spray the rest into the there. Here is the final picture of me spraying into the driver-side vent:
Once I was done spraying, I let the product sit for 30 to 40 minutes with my windows down, and then I went back to the car and ran the A/C for two minutes. During and after the application, there was little to no scent or odor. Just a mild scent that reminded me of the Einszett Cockpitt Premium.
I have not driven the vehicle yet and the car has only about 15,000 miles on it so it's not like anything smelled bad, except for all the cigarettes I've been smoking in there. I will update this review if I notice anything good or bad about the product once I have driven around a bit.
