Excessive Detail
- Apr 16, 2006
- 1,166
Has anybody used 1Z's line of pro polishes, whats your take and do they work good in direct sunlight like Optimum polishes?
I am starting to play with them, nice replacement for SSR's and Optimum. Not quite a Menzerna and a little harder to remove. Will tell more after some additional use.
I have used both the Intensive Paste and the High Gloss Polish. I definitely would not recommend it in direct sunlight; especially the 1Z HGP it dries faster than the IP, and it can be a pain to removeHas anybody used 1Z's line of pro polishes, whats your take and do they work good in direct sunlight like Optimum polishes?
The IP has a much longer working time, but no direct sunlight test by me
Let me know if you'd like to try a sample of either or bothThanks for the reply and the info, thats what I figured about 1Z, well I guess 1Z is out for me, thanks again.
I've been spoiled by Menzerna polishes, so I don't really see a need to try others.Has anybody used 1Z's line of pro polishes, whats your take and do they work good in direct sunlight like Optimum polishes?
I haven't tried them on very hot surfaces (never had a chance to), and since it's November, won't be able to 'till next summer.How does the menzerna polishes work in the sun for you, I have only done a few like that and it really wasn't that hot outside, so I really have not had the full direct sunlight experience with menzerna polishes, I know that optimum will work in the sun no matter how hot it is, which makes me almost want to stay with them, but they don't producwe the finish like menzerna.
