Reddwarf
- Mar 4, 2006
- 2,074
I just spent a lot of money fixing something that may have occurred as a result of using 1Z Kristall Klar Washer Fluid. I have only anecdotal evidence so I'm posting this to see if anyone else has had problems.
I mixed the concentrate per instructions and I emptied out the existing fluid. I used it for a couple of months and noticed that when I pumped it out it created a lot of bubbles or foam. Not long ago I topped off the reservoir and it foamed/ bubbled a lot when I poured the mixture in the tank.
Shortly after filling the tank the washer fluid began to foam at the nozzles instead of squirting out. It rapidly stopped pumping out at all. I took the car to the shop and they said the hoses and nozzles were clogged up. It had to be flushed out and the nozzles still don't work as well as before. I didn't want to pay the money for new nozzles.
I don't know for certain that the 1Z product caused the damage but I'm sure not going to try it again or on any of my other cars. I have used other 1Z products with much success and happiness. Has anyone else experienced such a problem with the washer fluid product?
Anyone want the 90% full bottle I have?
