2 Must Haves - Thrifty Info Inside
ehuth1
After reading a thread on autopia about some Dawn power dissolver, I decided to give it a try. I picked up the product from Wal-Mart so I'm sure if you find this review helpful then you should be able to get your hands on this.
After getting the sink water warm I spritzed about 4-5 pads and let them sit in one side of the sink while I washed one at a time. The intructions are for grease on cooking utensils, so I just followed what I read on autopia's site. Spray, let sit, massage under running water (also used the edge pad cleaner *perfect for stubborn stains and ergo friendly :thumb:) and air dry. Now don't get me wrong I've done this before with APC, soap, etc..... This my friends is the $hit when it comes to getting something done QUICK!
PADS
NOTE - I wore nitrile gloves to keep me away from the cleaner + the heat from the water....
After 25 second soak and 20-30 second agitation.
I give this product a huge :thumb: due to it's ease of use and cleaning ability. Thumbs down to you get what you pay it comes in a small bottle, so prepare like me and buy 2 at a time.
If you want to spend $125 for a pad washer thats completly up to you (it probably cleans better), but I think I've found something to fill the gap. Pads are still wet so however you look at, pics my be deceiving... They are clean and make the kitchen smell good too!
I'll tell you another use. It is exceptional at cleaning latex paint out of paint brushes. I just tried it a few days ago and wow.
Ive always found the DP Citrus Pad Cleaner to work just as well ...
That stuff is great!! I use it all the time on my Weber smoker after cooking some ribs. Over the years there were rumors it was going to be discontinued but thankfully that never came to fruition. Will start using for car stuff now.
Howard
Bought a case last year when the impending discontinued rumors were flying. Works great, especially for prophylaxis immediately after use before I can clean with the DP. Just spritz on a damp used pad and let sit until cleanup. Glad to hear it'll still be available.
you reuse your prophylactics? Im pretty sure they are single use only Im the MAN
Just make sure that you wear gloves when using this stuff. It is pretty strong.
ive used purple power and simple green as well... i will try this stuff though
It's still on shelves. Post seems to still be relavant to me. Better than creating a new one in my opinion. I'm glad someone brought it back up.
BTW, I look at post dates and I try not to reply to old threads if they aren't relavant. However, if it is still relavant and a good post, I'll reply to it. I don't want you to think I am just posting blindly.
When air-drying your pads, place them velcro side up. Residual cleaner/water "could" effect the adhesive that holds the velcro to the pad. Please note that I didn't say it "would", I said it "could". Just my 2 cents.
