Justin at Final Inspection
Active member
- Feb 19, 2014
- 2,627
So this Gt350 came in to get corrected and coated before it's winter slumber.
Wash/Decon- Hyper wash, Nanoskin towel
Wheels/Tires- Megs Iron Decon, Mckees Tire rubber, Hyper dressing
Correction- For this one I figured I'd dust off the ole 3401 and have at it. 3401, Mckees microfiber pad, M100. Also used my new Flex PXE-80 12mm 3in setup.
Finish polish- 3401, IGL yellow foam, Hyper polish, Flex PXE-80
LSP- IGL Poly 1 year coating
Now for the new Flex PXE-80. So some of you know about my past experiences with my Ibrid. Although Rupes took care of it it still left a bit of a bad taste and I have always been hesitant to use it for fear of breaking. So when Flex announced the new PXE 80 I was stoked and placed a pre order asap. My other want was a cordless 3in setup to have 1 less cord to drag around while working.
It arrived while I was working on this GT350 so I got to unboxing and put it to work.
The batteries came partially charged and I got to right to work. I put one battery on the charger and the other one on the tool. I like that I can attach the backing plate to the chosen bit(3mm, 12mm, Rotary) without the need for a tiny wrench. As the bits have a textured grip to them to hold onto. For this test I used the 3in plate and 12mm offset along with a Megs microfiber cutting pad.
Initial impressions. Rugged, powerful and smooth! This thing is a paint slayer!
