Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
3 inch and 4 inch buffing pad options at Autogeek
Griot's 3" foam pads
Griots Garage 3 Inch Orange Polishing Foam Pad 3 Pack
Griots Garage 3 Inch Black Finishing Pad, Set of 3
Griots Garage 3 Inch Mini Red Wax Pad 3 Pack
Flex 3" foam pads
The Flex 3" foam pads work great with rotary or DA style pads, it's the taper that makes small pads work.
FLEX PE8 Rotary Foam Pads – 1, 2, 3 Inch Diameter
The 3" Flex pad will fit on this DA backing plate
3" backing plate
Buff and Shine 4" pads
Buff and Shine offers a Mini Spot Buffing Kit. The kit includes a rotary buffer backing plate with an adapter to fit the rotary buffer backing plate to a DA polisher.
Buff and Shine Mini Spot Buffing Kit
The foam pads and wool pads in this kit will fit on this 3" DA backing plate
3" backing plate
These LC pads fit the above 3" backing plate too...
Lake Country Hydro-Tech 3 x 1.25 Inch Foam Pads
Lake Country 3 Inch Flat Pads 6 Pack - Your Choice
If you can go 4" the Meguiar's 4" foam pads or the Cyclo 4" foam pads or the Buff and Shine 4" pads are great for that size category.
Meguiar's
Meguiars DA Compound Power Pads
Meguiars DA Polishing Power Pads
Meguiars DA Waxing Power Pads
Cyclo
Cyclo 4" pads
Buff and Shine
RUPES
And the RUPES 4" foam pads are tapered and killer! I use the white pads for machine waxing.
Rupes 100 mm (4 Inch) Foam Pads
Lots of options!
Flex 3" foam pads
3" backing plate
3" backing plate
Meguiar's
Cyclo
Cyclo 4" pads
Buff and Shine
RUPES
Lots of options!
