3 inch backing plate and 4 inch pad on a GG6?
Fishincricket
I swear I screw something up on every order! I read and read to make sure and get the right stuff, then I screw up anyway.
I decided to get the Hydrotech pad system and downsize to a 5 inch plate and 5.5 pad, like so many here suggest..
I also wanted to get an even smaller backing plate for the tight spots, edges, etc... The smallest LChydrotech pad is 4 inches so I ordered those then I guess I ordered the 3 inch backing plate, not realizing I should have ordered the 3.5.
So my question is:
Will the 4 inch pad be effective on a 3 inch BP, or should I call customer service tomorrow AM and beg them to alter my order to either:
A 3.5 backing plate
Or
A different set of 3 inch pads?
I wish LC made 3 inch hydro techs!!! lol I'm clearly nuts.
Well by golly, so they do!!
So would it be wiser to beg them to change my 4" pad order to a 3" pad order? I think that's what I'll do...
Your 3" backing plate is probably actually 2 7/8" which is perfect for 3" pads. While the 3" plate will work with 4" pads a 3 1/2 plate will support it better. For use with 3" sandpaper you should have an actual 3" backing plate made for sandpaper.
Before you are done you will need/want all sizes of backing plates. Get them all.
Arn't you glad you asked. :buffing:
lol, I've already spent too much. But I'll probably call them in the morning and get the 3" pads.
I agree I'll "need" them all eventually... Though I won't be sanding anything by machine any time soon.
lol Welcome to the club.
Or..... swap the 3" plate for the 3½". ;) I don't remember in the DA kit with the different plates in it and the 4" CCS pads... wasn't that a 3½? Anywho... dat's da' one me got and I love it. :)
Are the 3" pads really usable on a GG6 without an extension to move the pad farther away from the polisher?? It seems the BP/pads are almost the same size has the black housing which would make it very difficult to polish close to any protruding objects on a car. I have the 3.5" BP with 4" pads and have struggled with the idea of getting a 3" setup. Mike has also mentioned the 3" pads are a little difficult to use with a full size polisher as it becomes "tippy"--is this so?
Indeed, the expert advice says, at best, to "use caution and focus in the task at hand"...
Based upon this and Nicks expert advice I have decided to wait on the 3inch stuff until I can get the actual 3 inch polisher.
I settled on upping my ordered BP to the 3.5 inch. I change my mind often, don't I? lol told y'all I was nutz. ;)
I think you'll be happy with your choice. I love my 4" pads! They are great for spot corrections in between complete details.
