allenk4
In time out
- Mar 12, 2013
- 4,845
I thought I had it all figured out...
I have a FLEX 3401 with a customized backing plate for 5 1/2" pads, but I wanted something smaller with extended reach to get at the touch to reach areas that otherwise would require hand polishing.
I bought an adapter that allowed me to use a 3" backing plate for a rotary with Meguiar's Microfiber Pads.
Worked well for a bit...then it overheated the backing plate and the pad; melting everything.
I was using it on 5 with medium pressure, but I was working a small area for a relatively short period of time
It seems that the backing plate I used has a small "stump" that may be focusing the heat and causing breakdown?
Does anyone have input on a backing plate that might work better?
Results for 3" rotary backing plate - Search
