Recently I purchased a 6" 3m sander 3/16 throw for use with the trizact system
I have the 3000 and 5000 with interface for the da and was going to hand sand the 1500 because I've never done this before and don't want to go through....I thought about using the da with 1500....
The car is in the blocking stages of primer right now. It will either gets 4 coats of clear or 3 coats then sanded with 800 then 3 more coats. Then cut and polished
I also purchased the 3m polishing system
White
Black
Blue 8" and 3" pads with the corresponding compounds and polishes.
This will be used with an adjustable dewalt buffer.
Then went ahead and bought some 3" trizact 3000 and 5000 with the interface pad.
Now I'm trying to figure out what I should buy for a 3" machine.
I was looking at this 3" 3m set up
As said above I have the 6" one. What I was thinking is I could use the 6" and the 3" above for polishing and cutting as opposed to that buffer.
I have also been looking at the electric polishers PC, GG, FLEX, MEGS in 6" capacity. The 3" gg looks good but from what I've read it won't cut. I need something for tight spaces that will cut
Can I polish and cut with these 3m sanders?
White
Black
