3" sanding discs?
willowcat11
Member
I'm looking to buy 3" sanding discs in bulk to be used for headlight restoration. Does any one know of a good brand, or good deal that they would recommend?
Thank you All!
Ray
And if you can't get the right size in a pinch buy one up and trim it down....
Try any 3M Industrial Distributor. Industrial. U need to tell them Disc Rolls or Stikit. U don't mention the grades needed and I can only assume for clear coat. So that could mean wet or dry discs or Trizact.
And a pad if u need one. Good luck
If you purchase cheap inferior sanding disk you will be paying that price in more labor .
