3 - Types of Water Spots - Type I, Type II and Type III
Water Spots are more complex than most people assume because there are different types of water spots. Some water spots are merely mineral deposits on the surface left behind after water with minerals has evaporated off the surface. These deposits can often be washed off the paint using a quality car wash soap.
Sometimes these deposits can also leave an imprint in the paint in the perimeter of the spot and in these cases the imprint must be removed using a compound or paint cleaner as it's a defect in the paint, not simply a deposit on the paint. Some sources of water, be it rain with air-borne pollution mixed-in, or sprinkler water from a city water supply or well water, can have corrosive enough elements in it that it will actually eat into or etch the paint leaving a depression or crater in the paint where the water dwelled or dried.
A Type II water spot can only be removed by leveling the surrounding paint by hand or machine with some type of abrasive compound or paint cleaner.
Type III Water Spots are primarily a stain in the paint which looks like fading where water pooled and then dwelled for some measure of time. This primarily happens to single stage paints which tend to be more porous and thus will absorb water into itself. If Type III Water Spots are limited to only the upper surface of the paint then they can be removed by abrading the paint by hand or machine with a compound or polish.
Before attempting to remove water spots it is important to first diagnose which type of water spot is affecting your car's paint.
Type I Water Spots
These are Mineral Deposits or what people commonly call "Hard Water Spots". It's the minerals in water that people are referring to when they use the word "hard" in the term "Hard Water Spots.
Type I Water Spots are primarily a mineral or dirt deposit laying on the surface of paint. Type I Water Spots can be the results of minerals suspended in city water or well water that are left behind after the water evaporates off the finish. This can happen by washing a car but not drying the water off the paint or if a sprinkler goes off next to the car covering the car with water drop that are not dried off the paint.
Type I Water Spots can also be dirt or pollution particles left behind after water from rain or inclement weather evaporates of the finish. Type I Water Spots can also be Type II Water Spots in that the water can leave both a deposit on the surface and an etching in the finish.
More Hard Water Spots or Mineral Deposits Caused by a Sprinkler
When following the approach of using the least aggressive product to get the job done, the first thing you want to do is to see if you can either wipe the sprinkler water spots off or wash the sprinkler water spots off. Since this car was recently washed and waxed and it's kept inside a garage when not being driven, we're going to try to wipe them off using a spray detailer with a clean, plush microfiber towel.
When removing fresh water spots, use your spray detailer heavy, or wet. Using a product heavy or wet means using extra product, more than you might normally use. The reason for his is you want lots of lubrication on the surface to help prevent any potential scratching or marring of the finish as you're wiping.
Remember, always fold your microfiber towels 4 ways to give you 8 wiping sides with plenty of cushion to spread out the pressure from your hand and wipe the paint gently.
Start out by spreading the spray detailer around to one section and then flip or fold your microfiber towel to a fresh or clean portion to remove the residue and buff to a dry, high shine.
Luck is with us... the paint is safe as the Sprinkler Water Spots did not etching into the paint and using plenty of spray detailer and a clean plush microfiber towel left a scratch-free finish.
Type II Water Spots
Type II Water Spots are actual etchings or craters in the paint because something corrosive in a water source has landed on the paint and was not removed before a portion of the paint was eaten or dissolved by the corrosive substance.
I took this photo myself when I helped Alex Fong from Corvette Forum remove a zillion Type II Water Spots out of the clear coat finish on his Corvette.
Photo Courtesy of MeguiarsOnline.com
Here's a close-up of the same photo, if you look closely you can see the edges are angled downward as this is an actual etching "into" the clear paint.
Type I and Type II Water Spots
In some cases, a water spot can be both a Type I and a Type II, that is you can have Mineral Deposits on the sitting on top of the surface and the water could have been corrosive enough to also etch the paint leaving a crater in the paint where the spot formed.
Imprint Rings
These water spots look like they're established water spots, that is, every time it rains, or a sprinkler goes off, the water pools in the same place giving any corrosive substances repeated opportunity to etch into the paint.
Visually, I can tell the paint is likely etched in this instance but I won't know till I get the surface clean. The first step is to wash or wipe the finish, in this instance I'm going to repeat wiping process I used on the Mercedes-Benz with a spray detailer.
After wiping the paint clean, there are water spot imprints remaining in the paint.
Type III Water Spots are spots that look faded or dull and are found primarily found on single stage paints after a water source lands on and then pools on the paint and is usually left to dwell on the surface for some measure of time before it evaporates or is wiped-off the surface.
Modern clear coat paints tend to be harder and impermeable, that is non-porous, so liquids don't penetrated easily and thus stain spots tend to be topical, that is only affect the very upper surface and are easier and safer to remove with a compound or polish.
Older single stage paints tend to be soft and permeable, or porous, it's common for liquids to penetrate into the paint and stain the paint below the surface. Removing stains out of single stage paints can be risky because in order to remove the stains you have to abrade the paint and if the stains penetrated deep then you risk removing too much in an effort to try to remove them completely.
Re: 3- Types of Water Spots - Type I, Type II and Type III
Was this a reprint of this article? I know I've seen this before.
But, in any event, love refreshing my memory on the different kinds of waterspots!
Good eye!
Here's what I have altogether on my article list.
Water Spots
How To Remove Sprinkler Water Spots
How to remove water spots by hand
And this one,
Tracers Tracers - RIDS - Pigtails - Cobweb Swirls - Rotary Buffer Swirls - Holograms - Water Spots - Bird Drooping Etchings - Micro-Marring
I've been updating the older threads with new pictures and I've extracted a little out of each of them to create a new standalone thread that just discusses the types of water spots.
This is for another project.
Great write up!
In your opinion, how does a claybar help in removing the mineral deposits?
I am going to be working on a silver Honda with water spots on the entire passenger side of the vehicle, including the glass.
The entire car will be getting claybar treatment regardless.
Is it always possible to get rid of Type II water spots? I've tried some surbuff pads with M105, (with PC 7424) and no luck. These things are pitted and somewhat deep.
Oops, sorry Mike. Just saw where you answered that already here:
http://www.autogeekonline.net/forum...5022-how-do-i-remove-type-ii-water-spots.html
Type II water spots suck. There is no getting rid of these that I'm looking at. They are pitted and pretty deep. I tried the Surbuff pad and M105, and they didn't budge. I guess a yellow pad isn't going to go any better. I'm a little scared to keep trying with the Surbuff and my old 7424. Can I burn through with a 7424? Speed setting 5 doesn't seem like it has enough power and speed 6 seems like turbo mode.
You can burn through with any too and even your hand, it's just a matter of how thick or more specifically, how thin the paint is how aggressive you're getting in your approach and of course how many passes you make.
When you burn through the clear, what you'll see is a dull spot somewhere that you're buffing. As you continue to buff the edges of the spot will start to grow or increase outward from where the initial spot started.
You'll also stat to see color on your pad whereas before you would have only seen the color of the product and the color of the pad.
Type II water spots are a nightmare if they're deep...
Wouldn't it be nice if car manufactures would put more paint on their cars?
Just wondering does water beading from waxing help to contribute to waterspotting,especially if an inferior wax has been used or a previously waxed car is still beading but the wax has lost it's (insert word) over time?
Oh forgot,or is this the reason some people prefer products for their sheeting ability not beading ability.I am aware that hosing the paint with a connection attached will bead the water as rain does and hosing with low water flow and no connection sheets.My question is; Is there a wax product that will make my paint sheet in the rain (without driving it) or am I looking at sealant to achieve this result?
CHEERS
Just wondering does water beading from waxing help to contribute to water spotting,especially if an inferior wax has been used or a previously waxed car is still beading but the wax has lost it's (insert word) over time?
Actually, anything that causes and increases surface tension causes water to form beads and then if not removed could leave some type of spot on or in the paint depending upon what's in the water.
I worked for Meguiar's during the NXT vs Zaino Wax Wars raged through the forum world and the lesson learned by marketing management was that if a wax doesn't bead water well and for a long time the perception by "people" is the wax isn't protecting the paint or lasting on the surface.
People can talk about products that sheet all day long but common sense goes out the window and these types of products won't sell well because people like to see water beading.
People hate water spotting, but all that is forgotten until it's a problem they have to deal with personally on their car's paint.
The two most common questions I get e-mails about are,
  • Water Spots
  • DISO
:D
I see that the Detailer and microfiber towel took away type I wet spots and it didn't work on Type II Water Spots.
What can i do to remove Type II and Type III water spots if a regular car wash / dry , and quick detailer didn't work ?
You need to use either a polish or a compound and best results come from machine application.
Most important, find out the root cause of the water spots and avoid whatever it is that's causing them. This mostly applies to people that park next to sprinklers. It doesn't do any good to remove water spots and then park next to a sprinkler again.
Believe it or not, I've met people that couldn't figure that out.
:dunno:
You should write a book. Oh wait, you did!?! And I have a signed copy!
I just encountered some nasty type 2 water spots on an 07 M5 from New York City. I was doing a courtesy detail for friends of mine that own a high performance auto shop (the last shop that had the car had abused it badly so we/they wanted to clean it up for him). I worked with Megs 105 with a 5.5inch yellow CCS on my flex 3401 at speed 6 and it wasn't even getting the job done. Being that it was a "courtesy" detail, we decided to let them be as opposed to wasting time and possibly causing any damage to the paint, so I hit it with Klasse AIO and covered it up with Blackfire Midnight Sun wax, it came out looking fantastic under normal light, but it was still a nightmare (to me) under the high power flourescent lights. Bottom line, the customer was happy that we took care of the car.
But.. the spots are still driving ME crazy. What could I have used or done differently to get these things out?
It looks like I have type II water spots on my 2004 Mach 1. Some of them have a dull look to them on the inside of the etching's or "craters". I went to a body shop and they had told me they were acid rain etchings, but I didn't believe them at the time, because they told me they would fix it by giving me a new paint job for $4500. I thought they we playing. I had never seen paint with these etchings on it before, so I came here to discuss the prob with you guys.
I enjoy working on my car and would like to buy the tools and materials needed to tackle this myself....BUT, this seems like it might be a bit too much to tackle for a noob at machine detailing.
This link below is a post on my problem with a link to a video of my paint.
http://www.autogeekonline.net/forum/auto-detailing-101/65255-paint-issue-etching-2.html#post878940
I would like some advice on a noob tackling this type of water spots. I would purchase the porter cable model for some added protection, of course. But, even with that, is it too much for me to tackle? Thanks
Sorry to say we missed your post to this thread.... where you at with this problem?
Thanks, no change really. I visited a local detail shop last fall and they said they could make it look a bit better, but the larger etches would remain. I have purchased a DA buffer mainly to make polishing easier, but I have yet to buy pads for it.
