I'm looking to do my 2nd annual detail on my black F150. I have some very light swirls I'd like to remove while also prepping the paint for Meguiars M27 sealent.
Will 3D One with a 3D foam polishing pad leave swirls that would require another step to clear up? The instructions on the bottle only make mention of using it as a compound with a cutting pad and then using with a finishing pad for a 2nd step. I'd like to keep with only doing a polish and then finish with the M27. I know black paint can be a PIA.
The reason I'm using the 3D One is because I still have an unopened bottle that never got used. I read the thread on here by Mike about synergy between products so I wouldn't be against getting some M210 to use instead. But not if it isn't necessary.
Thanks!!!
Sent from my SM-G970U using Tapatalk
Thanks!!!
