PA DETAILER
- Mar 5, 2011
- 5,988
- 215
I'm halfway through my 1st gallon of 3D Pink. My opinions are that it's a very basic soap. Doesn't smell particularly good [it's supposed to smell like bubble gum but doesn't quite hit the mark]. Suds are good, lubricity is good, as is cleaning ability. I switched to this from Megs Shampoo Plus because I wanted a soap that didn't have any gloss enhancers etc. but it doesn't rinse as clean as I had hoped..
If you're looking for something that foams up real good in a foam gun this is probably the best you'll find.
But for my personal needs, I'll be looking elsewhere once I'm done with this gallon. I'll probably try Carpro Reset, Rupes Shampoo, or maybe even give Megs Hyperwash another try.
I recall you didn't like hyperwash and I recall your photo with the lack of suds. I will tell you that you won't like Rupes shampoo because it has that same feature. I have a review of it on the forum as do a couple others showing the same thing. Rest is good but it's going to be very similar in that department as well. Not as much as Rupes. I never had an issue with hyperwash.
I moved from a house with a water softener to one without one (so far), Hyperwash foamed well with soft water but much less with moderately hard water. Some soaps were less affected like DDJ BTBM. The water can be a variable.I recall you didn't like hyperwash and I recall your photo with the lack of suds.
