D DrWill New member Joined Mar 20, 2015 Messages 4 Reaction score 0 Mar 22, 2015 #1 Hi, Is there a way to remove scratches/swirl marks from a 3M clear mask? If so, how? Thanks
FUNX650 New member Joined Dec 1, 2010 Messages 21,057 Reaction score 1 Mar 22, 2015 #2 Since it's a 3M Clear Mask 'film'... •I'll suggest to use a DA polisher with: -3M Perfect-It Ultrafina Machine Polish #06068 3M polish, 3M ultrafina, ultra fine polish, 3m car polish, rotary polisher, finishing polish, final polish on the: -3M buffing-pad #05733 3M Perfect-It Plus Ultrafina Foam Polishing Pad, ultra fine polishing pad, foam buffing pads, 3M Perfect It pads Note: •If you need to go a little more aggressively, use: -3M Perfect-It Machine Polish #06064 3M Perfect-It 3000 Machine Polish, 3M 06064, remove swirl marks, 3M Perfect It Swirl Remover on the: -3M buffing-pad #05738 3M Perfect-It Plus Foam Polishing Pad 8 inches, car polishing pad, buffing pad •I'll further suggest to: -Use very little down force on the DA polisher/pad -Do not linger too long on any area: keep the polisher moving at all times!! Bob
D DrWill New member Joined Mar 20, 2015 Messages 4 Reaction score 0 Mar 22, 2015 Thread starter #3 Thanks, I'll give it a try.
