3M Flex conversion adapter
Lonewolf2007
Does anyone know if a smaller backing plate can be attached to the 3M adapter?
Does the 3M adapter have a 5/8 inch diameter shaft?
I was looking at the 4 3/4" or the 3 3/4 " backing plates.
LC-43-095 3 ¾ inch Rotary Backing Plate
LC-43-125WH Rotary 4 ¾ inch Flexible Backing Plate
Thanks.
After installing the 3M Edge adapter, you no longer need any backing plate. You use all the Edge pads which are dual sided and snap into place. Any of the PC pads will work fine and the smaller Cyclo ones too.
Killrwheels
Thanks for the Reply.
I just purchased my Flex 3401 and the 3M adapter.
I know it is for the Edge pads, but I see that it is threaded under the adapter and was wondering if a rotary backing plate would fit?
That way I could also use smaller Lake county buffing pads on my Flex.
I didn't know if anyone has tried to see if this was possiable, as I don't have a rotary and did not want to purchase something I could not use.
The backing plate included with the Flex is unique .. to my knowledge no other backing plate exists currently. (besides the Edge of course)
Killrwheels
No it won't the rotary is a right handed thread and the edge one is a left handed thread.
Thanks for the reply Harleyguy.
Thats what I wanted to find out.
