3m pad comparison?
fech
Member
I just got a couple 3m pads as a gift and am trying to research what the cut on them is. But I can't find a comparison chart anywhere. I did however find a site that said the foam was the same as lake country. Does anyone know if this is true?
I have the White, grey, and blue perfect-it pads.
Thanks in advance for the help.
If you look at the links that Waxy provided you'll see that the white is a compounding pad, the gray/black is a polishing pad and the blue is an ultra fine polishing pad.
Maybe I'm not asking the question right. I know what their cut is, I just have never had them before and was curious if they are comparable to lake country cut wise by color.
Hi, Dan with 3M here. These pads are designed to be used with our Perfect-It Paint Finishing system. The white pad is to be used with our Perfect-It Rubbing Compound, 06085. The black pad to be used with our Perfect-It Machine Polish, 06064, and finally the bue pad with our Perfect-It Ultrafine Machine Polish, 06068. For more information, visit our website at 3M.com/automotive.
Good Luck!
No, they are different.
