Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
3M Trizact 6 Inch 3000 Grit Performance Sanding Disc 01459 - Singles
We now have in stock the 3M Trizact 6" #3000 Grit Performance Sanding Disc in single packs from 3M for people that just need to do some spot sanding and don't need an entire box of discs. We also carry the 3" #3000 Grit Performance Sanding Discs for spot sanding minor imperfections of sanding thin panels or working in tight areas.
All three of these discs are for damsanding, that is they are designed to be used wet, not dry.
6 Inch 3M #3000 Grit Performance Sanding Disc
3 Inch 3M #3000 Grit Performance Sanding Disc
Sanding out an isolated defect
Working close to edges, thin panels or tight areas...
Machine sanded with 3M Trizact 6 Inch 3000 Grit Performance Sanding Disc
As an option to make removal of #3000 Grit Sanding Marks faster you can re-sand using #5000 Trizact Foam Finishing Discs
The below panel was re-sanded using 3M #5000 and now it's starting to reflect images like it was polished. Removing sanding marks this shallow is fast and easy.
Box of 15, Single Pack and box of 15 in the 3" size
On Autogeek.net
3M Trizact Hookit 3 Inch Foam Discs P3000 - 02087
3M Trizact Hookit 6 Inch Foam Discs P3000 - Box of 15
3M Hookit 6 Inch Soft Interface Pad - 05777
Also see,
Video: Wow! 3M #5000 Grit Polishing I mean Sanding Discs!
On Autogeek.net
Also see,
