I don't think most ceramic coatings actually layer, because once the first layer is cured, it will essentially repel anything you try to put over it, including any additional layers of the very same coating. And if it didn't cure yet, then by trying to apply a second coat you will just essentially remove the first coat - or at least make it mix with the new one, as the solvent will with no doubt soften the first coat.hi, I ceramic coated my brand new car with cquartz UK 3.0, 7 days ago. I did 2 coats. I like to 3rd coat , can I do 3rd coat after a week, or is it too late? . ( reason is I am not sure if I scrubbed gently or too hard causing removal of ceramic coating)
I've used the McKee's 37 paint coating V2. I only applied one coat and its held up really well. I can't remember how long ago I put it on but the beading is crazy. Of course, I topped mine with 10 minute paint sealant!I stand by the fact that with Cquartz there's no benefit. One solid layer properly cured is all you need. Various products differ in this aspect but I've used it for a while and one coat is good.
