Flash Gordon
- Feb 6, 2010
- 11,462
- 465
My local Lowes had it at Christmas for $300ish and when I went to get it it was SOLD OUT! argh. But I am intrigued too. I want the 3000PSI when I need it, and want to use 2000 when I don't. I just don't like the concept of washing a car with the gas PW for the simple fact that when I set the gun down, I don't want to have to kill the engine and start it back. Is that still the way you have to do it?
Flash...
You're much better off buying a pressure washer that has a Honda GX engine and a CAT triplex pump.
Is there a unit that you'd recommend?Yep^ Some pressure washers come with a regulator so you can adjust the pressure.
You want a Honda engine because they last. And you want a Cat or Triplex pump because they last. Unless you intend to use this a couple times a year, I would invest in a pressure washer that has the good parts. Don't get caught up in any gimmicks or the color of the paint.
