4-in yellow cyclo vs LC yellow
Bunky
How does does the yellow cyclo pad compare to a LC yellow pad in terms of cutting? I have seen charts comparing other pad makers but none list Cyclo foam pads. I have been using 4-in cyclo but need some yellow pads.
Keep in mind there are two kinds of yellow Cyclo pads.
Ok...On AG, they have two yellow pads although one looks more neon yellow. Would the lesser aggressive pad be similar to LC yellow?
The description reads: The yellow cutting pad is intended for more aggressive swirl and scratch removal. It is made of dense foam and will work well with compounds and advanced swirl removers. This pad is comparable to our Wolfgang™ yellow cutting pad.
The other one is called a Yellow Scrubbing Pad and I had not really noticed it until now.
the cyclo pad is thinner but i hv not notices a cutting difference compared to the LC yellows. I use both.
Thanks. I have used the orange cyclo and CCS pads. I liked the CCS pads better since they did not seem to suck up the polish as much, cleaned better, and the velcro seemed better.
