5.5" or 6.5" hd foam pads?
Detailchick
Which size do you prefer and why? and do they both fit on a 4 3/4" Lc flexible backing plate. Its for the makita rotary. Im probably gonna get the three pack I'm thinking the hydro tech ones are the way to go.
Its nice to have both size pads but the smaller pads are easier to handle where as the larger ones are nicer for horizontal surfaces .
Both pads are probably ok on your backing plate but the 61/2 may have a tad bit more overhang then ideal.I dont ever use 6 1/2 pads so maybe some one else who does will post.
The hydro tech pads are really nice but you must not over saturate them or use them damp/wet or they can shred and not last long at all.Also they take longer to dry after you clean them .
4 3/4" backing plate may be fine with 5.5" pads.
You need 6" plate for 6.5" pads.
I would get the 7/8 pads vs the 1.25 inch .
I made the mistake of getting the thicker pads and found them harder to controle on the rotary.
