Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
5" and 6" Backing Plates on 6.5" pads (Pictures to show safety margin)
Below are the new Lake Country Hydro-Tech 6.5 Inch Foam Pads with backing plates affixed to show the fitting comparison.
The backing plate on the Cyan Cutting Pad is the The Edge DA-500 Backing Plate, which measures 4 7/8" in diameter.
The backing plate on the Tangerine Polishing Pad is the 3M Hook-It 6" DA Backing Plate and it measures 5 7/8" in diameter.
This is to give you an idea as to how much safety margin of foam there is surrounding the 5" and 6" backing plates.
Also just to note, from a quick measuring of all the DA backing plates we care,
5" backing plate = 4 7/8" Diameter
6" backing plate - 5 7/8" Diameter
Exception
Meguiar's W68DA = 5 7/8" Diameter for the Velcro but there is a lip or rubber surrounding the Velcro portion that measures approximately 1/2" so the total Diameter of the backing plate is 6"
You can see the rubber lip surrounding the Velcro in the below picture,
This extra material is a matching design feature for their Softbuff 2.0 Pad System as the entire backing plate nestles inside a perimeter of foam.
I compiled the above because of a question that arose about which backing plate a person should get if they only wanted to get one backing plate but be able to use it for multiple pads. While it's always best to match the best backing plate size-wise to the pad being used, if you're only getting one backing plate whether with an initial purchase or as a replacement, here are two middle prices options,
Note the Edge DA-500 no longer looks like the image in the store.
Meguiar's W67DA
***Update***
Here's 5" backing plates on 5.5" pads to show how they fit. Shown are the Meguiar's W67DA and the Edge DA 500 on 5.5" Hydro-Tech pads and 5.5" CCS pads
5.5" CCS pads
Exception
Meguiar's W67DA
***Update***
5.5" CCS pads
