For the past couple weeks I have been slaving away on the 50$ Rustoleum Paint Job. I didn't exactly go about it efficiently where I wanted to experiment on some parts off the car.
Oh the hood I sanded it down, primered 2 times, sanded, 2 coats of paint, sanded (600 grit), 2 coats of paint, sanded (800 grit), 2 coats of paint. After about 4 coats it looked really good but as everything I read said a minimum of 6, I kept going.
After the 5th/6th coat, it now has insane orange peel and the reflection looks like stained glass. I don't really get why as I spent hours sanding out 75% off the orange peel before these last coats as per instructions on the net, but the end result is incredibly disappointing now. I suspect it may be due to the last 2 coats being made a bit thicker than the first ones and perhaps not laying flat.
Once the 6th coat dries, should I...
A) Go ahead and sand with 1500/2000 then use Meguiar's Compound.
B) Sand it back down again and lay 2 more coats before proceeding to Step A?
