Two years ago, I needed a cheap daily driver in short order and ended up with a 92 Integra with just over 200K miles on it. It appeared to have what I'm guessing as a cheap single stage paint over the factory paint. I didn't get it to make it a show car, but I wanted to at least have it looking decent. Even after multiple washings and my first ever attempt at using a clay bar, it looked like there were stains embedded in the paint. For a while, I gave up until I found this article on a search for cleaning stained paint: http://www.autogeekonline.net/forum...w-car-finish-antique-single-stage-paints.html
Here are my before/after pictures after applying the first coat of Meguiar's #7 this weekend. It will sit until later this week when I can wipe it off and try a second coat.
Before:
After:
Using the clay bar on the bumper started out like I was going over low grit sandpaper. I removed the Integra logo because it was about to fall off. I plan to re-apply it before I get to waxing. The pin striping was removed the first time I used the clay bar when I had bought the car. I don't miss it.
Before:
After:
The door had the worst staining.
Before:
After:
The embedded greasy palm print is now gone!
Before:
After:
It may be hard to see, but in the center of the trunk lid, there was a circular mark that looked like someone had stuck a magnetic mount CB antenna in that location.
Before:
After:
Before, there were stains running down from the gas tank door, and now they are gone!
Before:
After:
It was a lot of hard work, but it was motivating to see the stains disappear as I worked in the #7. Even without having wiped off this first coat, it's already looking way better.
Before:
After:
Before:
After:
Before:
After:
Before:
After:
Before:
After:
Before:
After:
