Tropicality
- May 30, 2007
- 75
I have had different things that came to mind over the past few weeks and I'd like to find the answers.. so if you would be so kind, here they are!
If you have a swirl-free finish and then apply a sealant+wax to it, and then a week later induce minor swirls, are these swirls just in the wax/sealant, and by removing the wax+sealant, will it take these swirls away? Using logic I'm guessing that its a yes, unless the scratches get deep enough..
When there are aftermarket things painted onto a vehicle, such as flames or stripes, do you have to be really careful in polishing these due to the thin layer, even with a DA + light polish? Even if the answer to that is a yes, is it probably best not to go over them unless yoiu know for sure that there is a clearcoat layer on top of it?
Can a PC take bumps off from above the top layer of a finish? Such as small bubbles in the clearcoat?? Or can it only remove stuff that is below the top layer such as swirls? If it cannot - then does a rotary? If not, then is wetsanding the only answer?
With vinyl stickers, I'm guessing - don't take the PC near them? Is it okay to apply a sealant or wax over top of them? Or will it wreck them+change color by absorbing into it?? If that is a 'depends on brand answer', what brands are best for vinyl emblems/trim? DG #111? Souveran Liquid Wax? Is Klasse AIO okay over vinyl stickers that are on windows?
If any of you were to buy a brand new vehicle, would you take it and get another clearcoat layer put onto it?? Reasons why and why not??
Who holds this patent to yellow clay that prevents it from being sold in the USA?
As always, thanks alot for the input!
