A Foam Pad cleaner from Meguiar's you should try out
Kamakaz1961
I know we all have searched for a good foam pad cleaner.
I use Lake Country CCS Pads, Hex Logic Pads, and a variety of foam hand applicator pads (Lake Country and cheap $1 throw-aways for waxing the wheels).
My current Foam Pad cleaner is Chemical Guys, XMT and Grit Guard Pad cleaner. I like CG better as it is not as harsh to the nose than the GG and XMT cleaner. The problem is that you have to order these products as they are not readily available in your local Auto-parts store. I ran out of all (such a noob) and wanted to clean my pads after working on my ride.
I decided to go to Walmart and see if they had any pad cleaner and as always no foam pad cleaner. HOWEVER, there was a cleaner for something we all have seen and I never thought about it when you see it. Since I wanted to clean my pads and did not want to wait for an order; I read the directions to the following Pad Cleaner:
It's made by Meguiar's and it is called the DynaCone Pad Cleaner. It does not say it is a foam pad cleaner, except specifically for the Dynacone foam pad. I am perplexed as to why it says it is specifically for the Dynacone only (their yellow foam cone wheel cleaner that is attached to a drill).
IMO a foam pad cleaner is a foam pad cleaner regardless if it is for a specific foam pad. Foam Pads are just it: FOAM! There is no difference in concept. Additionally, it was less than $5 so I took the massive $$ risk and bought 2 BOTTLES!
The directions says to clean the pad with the cleaner 1st, then saturate the pad with the foam cleaner and then soak the pads in warm water for 15 minutes. That was the only difference. Additionally, when you inhale, your nose does not hurt from chemicals being inhaled (something we all should not do anyways) like some other pad cleaners.
I tested 4 foam pads that I use as throw-aways. These pads are in way worse condition than my DA pads as they had old wheel wax, tire gel, and other crud; extremely dirty pads.
To my surprise 2 of the hand applicator pads were almost brand new! No gunk or wax on them (my $1 wheel wax yellow foam pads). The 2 tire foam pads (3" Griot's Blue Pads I use for tire gel) had most of the gunk gone! They were still black from the tire gel, however, the greasy feel was gone. I could re-use all of these pads!
I then tried the same procedure with my Lake Country 6.5" White CCS pad and it was like brand new IMO it cleaned better than CG, XMT and GG Pad cleaner!
I will no longer be buying any of the aforementioned pad cleaners. They cost more and I usually have to order them and that takes a 2 - 7 days to get them. Now I can just go to Walmart or your local auto-store and just get the Meguiar's Dynacone Foam Pad cleaner.
I would highly suggest you try it and see if it is better. Additionally, it is only $5 so if you do not like the product your out just $5.
AUTOGEEK Does sell the product too!! Just search under Meguiar's Dynacone
I hope this helps everyone that needs to clean Foam Pads
:dblthumb2:
:goodpost:
WOW !!!
This is good news. Thanks for your efforts and that " $$ leap of faith $$ ". :xyxthumbs:
In all seriousness, the price is definately worth it.
So the pads seem to become clean (or even cleaner ) but have you got around to using a pad after executing this cleaning method.
I was just wondering if there would be any "ill effects" on the pad and if it would perform normally as when the traditional method of cleaning is used.
:goodpost:
WOW !!!
I would assume it will be fine. I checked them after they have dried and it "feels" fine. IMO it feels cleaner than with the other pad cleaners. I will probably try one of the pads here soon just to make sure. My guess it should be fine.
:buffing:
Cool, I may try this. How far does the 10 oz. bottle get you?
I do not know as I only cleaned 5 pads. There is still alot of pad cleaner left. Either way, at around $5 a pop instead of $8 - $12 a pop is a good thing.
I would assume it should be about the same as the other cleaners.
:props:
I really do like this stuff. I got the 4oz size in my Dynacone wheel kit but love using it on all types of foam pads. Gets the pads feeling very clean with a sort of new feeling that is restored.
Bought 3 bottles and tried it out yesterday on pads I already cleaned and they came out cleaner. Foams nicely and doesn't run either. My new go to pad cleaner!
Pad cleaning is a necessary evil unless you use a pad then throw it away....Which I do not.....
This is really good to know. :props:
Here's a link directly to the product.... Meguiars DynaCone Pad Cleaner
If I didn't have a few bottles and a gallon of Chemical Guys Foam and Wool Pad Cleaner left I'd be on top of this.
For the price you can't go wrong at all.
Do they only sell it in a small size?
LOL..... "it was less than $5 so I took the massive $$ risk and bought 2 BOTTLES"
Good to know, i'll look into the product. I currently use Snappy pad cleaner.
I just cruised by my local AutoZone and WM, and neither of them have it on the shelves yet.
This product has been unavailable for some time now. It's very strange. It isn't even available from Meguair's Direct. I've picked up a gallon of Pinnacle's pad cleaner because the reviews seemed good but it smells, very suspiciously, like 409 or Fantastik to me.
I'm conserving what Dynacone pad cleaner I have left. I've been using Dawn to get the worst of the wax/sealant out before I use the Dynacone pad cleaner. Dawn seems to work really well.
Yeah I noticed this to. I even asked Micahel Stoops if it was discontinued over on MOL and he said no. So hopefully it comes back. It's availabe on Amazon but shipping is high.
I use LA Totally Awesome on pads. Cheap and very effective.
Sent from my iPhone 5 using Tapatalk
LOL I hope it didn't break you and you still had enough $$ for lunch!!
:props:
AutoGeek sells the Dynacone pad cleaner for 4.99 per bottle. Just do a quick search and it will come up.
Ed
Eandras: AutoGeek sells the Dynacone pad cleaner for 4.99 per bottle. Just do a quick search and it will come up.
Yes, that's the price but the product has been unavailable for weeks now.
Hey all, i have been looking for a couple of bottles of the dyna cone foam pad cleaner because i am almost out. Cant find any locally and every site that has them listed they are unavailable or on temporary back order. Today i googled them and the first thing to come up was 8 (10oz) bottles on ebay for $45.00/free shipping. I wasnt looking to buy 8 bottles but that comed out to about $5.50 per bottle. I think that i paid $6.99 at pep boys for the last bottle. Anyone know of any other suppliers? If not i think i am going to order them from ebay. The listing says 5 available at that price, so if anyone else is hunting for some, I thought id pass it along
