FMINUS said:Is simple green a good choice? if so which one?
I am looking to use this for the engine bay, undercarriage and lower bumpers/sides.
THANKS!
I personally like Zep Citrus Degreaser. It about $9 for a gallon at Home Depot, I cut it with water 1:1, for engine - works excellent. I use the same strengh on wheel wells. For lower half of car I cut it 4:1.FMINUS said:Is simple green a good choice? if so which one?
THANKS!
supercharged said:I personally like Zep Citrus Degreaser. It about $9 for a gallon at Home Depot, I cut it with water 1:1, for engine - works excellent. I use the same strengh on wheel wells. For lower half of car I cut it 4:1.
One the other hand you could give DP a try (I used it and really liked it), especially on a car like your M3. Be sure to cover altenator, and all belts before starting.
Good luck.
ZEP CD is an outstanding product!FMINUS said:I ended up going with Megs super degrease, $15 for one gallon. I will probably also pick up the citrus one just for kicks!
