ExoticAutoDetai
- Nov 30, 2010
- 935
Anyone know a good foam soap and what dilution would be good to use with a concentrated soap for a 32oz bottle?
How many oz you used?I use DP Extreme Foam. Foams up great in my foam gun and in a bucket. It smells like spearmint.
good stuff! :xyxthumbs: i use this in my gilmoure foam gun. about one pump from the gallon container. 2-3 oz. i use the next to last setting on the gun. only other foam soap that i have used that gives the DP a run for the money, is CG maxi suds II. if not a tad better? than the DP.
i used this stuff and cant get mine to foam like this can you help out ? turned down the power on power washer and still not to good . foam but real runny come wright off
I just play with the mixture knob until I get a good thick foam. I have a foam lance I got off of ebay (same thing as the foam cannons sold here at AG). I have a 1500psi electric PW that I use for this and it really seems to work well for me.
I should note that when I'm doing a winter clean up or a heavily soiled car I'll add in some APC to my mixture, usually about 2 oz. This seems to bump up the thickness as well. The pics of the Accord and Equinox are this mixture. The Porsche was just straight DP Xtreme foam.
:iagree: I use this in my foam cannon and my 2 bucket wash. It really leaves a thick blanket of foam on the car. I use about 2-3oz for my 32oz foam cannon bottle.
Here are few pics..
the DP is thick.
