A wheel/tire cleaner I mixed...works well...
m4gician
Hey folks,
I mixed a wheel/tire cleaner that seems to work well for general cleaning. It's a sudsy cleaner that cleans tires well (from what I've seen) and does a good job of maintaining clean wheels or wheels that don't need a dedicated wheel cleaner.
Mix 1-2 oz. of Liquid car wash (i used PB SSS)
with 8 oz of ARO.
It's a strong sudsidy solution that I love using it.
Ideally I think dilution rate should be 8:1 or great ARO to soap.
Hmm sounds cool, any pics? Especially since ARO is water activated. Did you see better cleaning then just ARO alone, or was it similar and basically doing it to save cost (less use of ARO).?
Ya I'll demonstrate it once this last snow fall finishes. I found it to STAY on the wheel more with a sudsy action. The suds stayed on the tire and slowly melted off. If you use a PW, you'll see a lot of lather build up rinse right off.
