Work in a shaded area. Make sure the paint surface is cool to the touch. Make sure the surface is very wet before applying the Hydro2. Start at the top of the vehicle and work your way down and around the vehicle. work on 1 panel at a time. Rinse off the panel with pressure washer. 1 or 2 sprays per panel is all you need. Less product works better.
So if I was gonna apply a glass sealer should it be before or after the hydro 2?
Sent from my SM-G955U using Tapatalk
