Accidents Happen
rwright
So today I'm working on a Toyota Camry and prior to washing the car I decided to clean the gas door from what looks to be mold.
I simply sprayed Optimum Power Clean at full strength on the affected area and proceeded to brush with a boar's hair detail brush followed by a micro fiber towel dipped in car soap with NO dwell time. After rinsing I was left with the following:
This is not a slam against Optimum so please do not take it that way or re-post it as such. This is the first time this has happened in the 3 years that I have been using Power Clean, even at full strength. Remember there was no dwell time here so it's not like I was careless and let the product dry on the surface. Could the mold or grime have weakened the paint? Possibly, but there is no way of telling at this point. Should I have reached for my 3:1 mix and use it? Possibly, but that ratio could have or could not have produced the same results.
I immediately contacted the owner and shared the same pictures with him via text and offered to pay for paint repair, he simply said don't worry about it and thanks for the honesty and asked that I continue with the detail. Lucky break? Yes, but I still feel horrible about the situation.
Take care,
Richard
I'm looking at the pics on my phone and honestly don't see what the issue is? What am I missing?
Either way, honesty is the best policy and you did just that. I detailed a Tiburon earlier this week and while drying the car I accidently took off the T and told the customer right away, he said it happened when they got it too but I think he might have been just being nice. I asked for some superglue and he even said he'd take care of it.
You were honest. But I think that the damage is from poor workmanship from the car manufacturer. I would just put acouple coats of sealant on it so it is protected somewhat. Was the owner a repeat or new customer? If a new customer offer a discount on the next detail to show goodwill. If repeat customer I would also offer a discount on the next detail.
Ed
Did you have paint on the towel? While it's true that molds and fungi have to eat something, and that something can be paint, that looks like more of a (paint) prep problem having to do with the bracket welded to the inside of the door.
I can't tell because of the grime on the towel. I used a different towel and wiped the opposite direction with a polish and it had the same effect but sadly changed color.
This is a new customer through a referral. That's the toughest part for me because I hold my work to high standards.
Odds are good you removed paint that had already oxidized; those areas simply are not treated so this would be considered normal wear and tear as far as I am concerned. Still, I would have acted the same way you did. :-)
I think that was probably preexisting issue. I bet using water would have caused the same issue
That area does not have clear coat. It probally only had a couple swipes from the paintgun to boot
That was very honorable of you to tell the owner about this Richard :props:
I agree. You would think the paint would hold well there considering that gas is being poured through there, and accidents happen where gas can get on the door and if not wiped right away can eat the paint. You were honest and I'm sure that customer will be back. Keep up the good work.
Sent from my iPhone using AG Online
Flash is right, those areas are usually never clear coated. Pair that with them never being cleaned, mold, and gasoline, and the paint won't be very strong. I accidentally did the same thing to my mom's truck since it was the first time the gas cap was ever cleaned.
I agree. Areas like that just don't get much paint. Considering that the base colorcoat is water base on top of that, it certainly isn't very durable. Most people don't care about the the appearance of the inside of gas doors, honestly. If indeed that was mold, the fact that is is bare water based paint might be a cause.
Not your doing. Like the other posts it was a combination of a few things thin paint, no clear coat, no maintenance and then with the mold that paint was done for! I have seen mold deteriorate the paint on outside AC units many times. A very stout paint so it's no surprise what happened. I commend you for your honesty and customer service. Integrity is sometimes quite rare these days.
same thing happened to my accord. previous owner was my grandmoth and it sat under pine trees for about 2 years with her unable to drive before it was sold to me. I had mold there, in the trunk gutter area, door jambs etc. after cleaning with just carwash, it looked EXACTLY like this. not your fault, it was the mold in my opinion and experience. sucks, but thats how it is
