carguy said:Question on using a acid wash, i purchased a decomtamination system it came with acid wash can you use this to strip off everthing off the clearcoat to take wax,tar,and other stuff off before washing or it has to be used as the system a,b,c?:grouphug:
Thejoyofdriving said:Well I use 303 cleaner to strip off all the wax or road grime. 303 cleaner has a PH of 9 which is 100x more powerful than baking soda. But once its mixed with water it goes down![]()
I assume you could use the acid wash by its self.
:iagree:killrwheels@autogeek said:I would never use an acid unless needed. With the regimine of washing -- claying ---polishing --- protecting I just dont see the need for it.
TOGWT said:None of the methods cited will neutralize acid?
