For the past few years there has been a lot of talk about making one . I believe Lake country was looking into making one not sure if they still are . I actually looked into making one but from what feedback I got between the setup cost and design costs and production it was going to be close too $500.000 to get it going .just wondering if flex or someone is goin to make the adaptor so you can use smaller pads with there da
I will be a witness for you for my usual 5% witness fee.
Sent from my DROID2 using Tapatalk
Seems like a lot of torque on that metric bolt..dunnoWhy wouldn't something like this work? Anyone see reason why it wouldn't? Feedback please....
I all ready have a working model of one that I made that used the edge adapter on one side and the other end was 5/8 thread .If you like to see a picture of it I can post it .The only problem was the edge adapter was left handed threads .It has been documented here on AGO on this date that it was my Idea!!I'll be happy with 10% royalties.:hungry:
Were talking for 4" pads right? You really think that'd be too much torque? I may give it a shot and take one for the team. Worst I see is a potential EZ-Out fiasco.Seems like a lot of torque on that metric bolt..dunno
Try it, but imo why not use a pc with 4" pads?Were talking for 4" pads right? You really think that'd be too much torque? I may give it a shot and take one for the team. Worst I see is a potential EZ-Out fiasco.
Try it, but imo why not use a pc with 4" pads?[/QUOTE One of the reason I didn't move forward with it . With all the new machines that are out now and coming out no need to make something with so many other choices . I did it because I was boried .
I do that and I have the dynabrade adaptor that works well with 4" pads too. I guess i just like inventing little gadgets. Adam just reminded me why my Idea would fail. It would unscrew itself because of the opposite rotation. I forgot about that.Try it, but imo why not use a pc with 4" pads?
I wasn't thinking to remove the gear driven backing plate but to just screw this adaptor in as the bolt that holds the backing plate on the machine. Essentially the idea was to have 2 backing plates on it, but it's been scrapped.Hold on there, guys...without the OD gear on the backing plate, your forced-rotation Flex just became a PC...
Now that i've played the tape through in my head, I agree.Dave,
That would be my engineering opinion. Too much for that small bolt. Unless you tightened it down enough against the backing plate that the metric side saw only tension and the lateral accelerations were reacted by the shoulders of the wrenchable portion. I doubt the plastic would let you torque it down that much.
Oh, and that will be $50 for a rudamentary stress analysis.![]()
