Since a few months I am the proud owner of the 44th (out of the first 100) mass-produced Electric Vehicle (EV) to hit the roads here. It is a Renault Fluence ZE (Zero Emission), painted light metallic blue:
When the car was approx. one month old, someone scratched three panels on the side of my new car. Here are photos of these three scratches:
front
middle
back
According to the service center, repairing these scratches would require completely repainting these panels at a total cost of around $2,000.
As I am relatively handy and not afraid to take on something new, I have decided to try and fix one scratch myself and see how it works out. After all, I can always go back to the service center and have them repaint the panel.
I have already read most threads relating to deep scratch repair here. I know what sort of repair I can expect to accomplish. I must say there is an enormous amount of information available on this forum and the quality of the information is simply amazing!
In this thread I will summarize what I have learned from the various threads I read and movies I watched, and am asking for your feedback, advice, etc.
My current thoughts are as follows:
Order the following products:
1. Flex XC 3401 VRG Dual Action buffer
2. Additional backing plates
3. Car detergent
4. Wool and foam pads
5. Microfiber cloths
6. Isopropyl alcohol as solvent
7. Clay
8. Touch up paint
9. Sanding paper: 800, 1000, 1200, 1500, 2000, 3000
10. Sanding paper lube: ONR QD
11. Compound: M105 or 3M Perfect-It 3000 Rubbing Compound 16 oz. – 39060 for fresh paint and 3M Perfect-It 3000 Extra Cut Rubbing Compound 32 oz. – 06060 for cured paints (however is 3M only suitable for rotary buffers?)
12. Swirl Remover: 3M Perfect-It 3000 Machine Polish Swirl Mark Remover 16 oz. - 39061
13. Polish: M205 or 3M Perfect-It 3000 Ultrafine Machine Polish 16 oz. – 39062 (however is 3M only suitable for rotary buffers?)
14. Glaze: 3M Perfect-It 3000 Final Glaze 32 oz
15. Sealant: Wolfgang Deep Gloss Paint Sealant (or perhaps 3M Perfect-It Show Car Liquid Wax 16 oz. – 39026)
16. Wax: Pinnacle Souverän Carnauba Wax
You will notice I am attempting to use one manufacturer's system. I would prefer 3M but have noticed that some of these products seem to be meant for use with a rotary buffer only.
You will also notice I am not only trying to fix the scratches but also want to protect the paint on my new car as best as I can.
These are the steps I am thinking of following with the car parked indoors:
1. Wash with car detergent
2. Dry
3. Clay
4. Apply touch up paint with toothpick or similar, let dry for 12 hours, continue to apply layers until scratch has been filled
5. Tape off area of scratch
6. Wet sand with 800, 1000, 1200, 1500, 2000, 3000 using lube until touch up paint is level with original paint
7. Wash to get rid of sanding residue and wait until completely dry
8. Compound on wool pad
9. Remove residue with microfiber cloth
10. Wash with isopropyl alcohol (IPA)
11. Inspect in direct sunlight
12. Compound on foam pad
13. Remove residue with microfiber cloth
14. Wash with IPA
15. Inspect in direct sunlight
16. Swirl Remove on foam pad
17. Remove residue with microfiber cloth
18. Wash with IPA
19. Inspect in direct sunlight
20. Polish on foam pad
21. Remove residue with microfiber cloth
22. Wash with IPA
23. Inspect in direct sunlight
24. Apply sealant
25. Apply wax
Specific questions:
1. Is the Flex XC 3401 VRG Dual Action buffer suitable for this sort of work or can this only be done using a rotary buffer? As a complete novice I would much prefer not to have to master a rotary buffer at this time!
2. Are the above 3M products only suitable on a rotary buffer or can they be used successfully on the Flex DA?
3. Since the scratches are small, I would like to use small pads to work on them. What are the smallest size pads which can be mounted on the Flex DA given that it will only take specific backing plates manufactured specifically for this device?
4. Any recommendations regarding which specific wool and foam pads to use?
5. With what step from the above list should I start working on the entire car to keep the entire car uniform looking (i.e. should I compound the entire car (I think not) or polish the whole car)?
6. Anything you think I may have overlooked, or any other advice?
Needless to say I will make sure to take pictures and perhaps a video of the entire process.
I would appreciate any and all comments, advice, remarks, etc.
Thank you very much in advance!
Ariel
front
middle
back
3. Car detergent
7. Clay
8. Touch up paint
2. Dry
3. Clay
14. Wash with IPA
18. Wash with IPA
22. Wash with IPA
24. Apply sealant
25. Apply wax
Specific questions:
Ariel
