Aerospace 303 or DP interior detailer for interior cleaning?
mycarmycar28582
Which spray do you guys think is more effective in cleaning leather, vinyl, & plastics in your interior of your car?
The first item is the Multi-Surface Cleaner I assume? If so, never used it. The 2nd doesn't exist (unless something was released recently).
DP Interior Cleaner works great though and I highly recommend.
Neither of those products are cleaners. They are protectants.
If you want something to clean the surfaces first, try using a dedicated cleaner before you apply a protectant.
BLACKFIRE Interior Cleaner, dashboard cleaner, vinyl cleaner
While there are also all in one, cleaner / protectants, they tend not to be great at cleaning.
Therefore, if the surfaces in which you want to protect are in fact dirty, try cleaning them first before protecting them.
I use a diluted mix of Mrs. Meyers organic cleaner. Smells great, cuts dirt and greasy stuff, doesn't leave a residue. You can even clean windows with it. Best of all its available at most grocery stores in the cleaner Isle. Groit's interior surface cleaner is great too though.
