Let me see if I can dissect your posts and give you some answers without causing too much confusion.
I used some 3M buffing compound to remove the 2000 grit wet sanding on my black paint. It's color/clear.
I'm using the Porter Cable 7424XP. I started with the 3M compound wand yellow Lake Country pad then used Meguiar's Ultimate compound with an orange pad.
I'm reading that I should have used Meguiar's 105 and yellow pad and then 205 and orange pad.
If you're able to remove sanding marks using an XP with 3M and a 6.5 Yellow Foam Cutting Pad then you probably ought to stick with that recipe, you could try the M105 with the yellow pad and see if it's any faster or if it yields better results and if it does then alter your recipe.
This is where you do your testing or your test spot. Dial in a system that works for you. The goal would be to find a single cutter that will remove all the sanding marks. With the XP or a polisher like the GG ROP, if you hold the pad flat on a flat surface it will rotate a 6.5 pad just like a rotary buffer even under pressure, it won't have the power of a rotary buffer but it comes close enough for people that either don't own a rotary buffer or are not ready to move up to a rotary buffer.
So try to do some testing with your most aggressive foam pad and see if you can remove the sanding marks with just one product, there's actually a way to test,
- Sand a section
- Test 3M and your yellow foam cutting pad for 8 passes back and forth to just one portion of the section.
- Now duplicate this to a section right next to the first test section only used M105
Now compare the two sections. You should still have sanding marks as the goal is not to remove all the sanding marks, (that would/should take more passes), the goal is to see which product is removing the most sanding marks under a controlled test.
Does that make sense? If not then call me as this is pretty hard to teach with a keyboard.
After you dial in your recipe for removing all the sanding marks all you should have to do is remove any haze or micro-marring and restore a clear, high gloss finish. M205 should do this with a polishing pad for sure, and maybe a finishing pad, again test.
You might find that it takes the polishing pad to remove the haze and if you're in love with your truck you might want to maximize the finish with a finishing pad and the M205
The key is testing till you find a recipe that makes you happy and gets the job done and then duplicate this over the entire finish.
So if I use the 205 at this point I can use the polishing or finishing pad for that then to apply the wax. I can either apply the wax by hand or use the gray or blue pad.
See above where I talked about testing a polishing pad first and checking the results and then test a finishing pad and checking the results, use whatever level of aggressiveness in your pad selection to get the job done.
But, now for the rest of the question.
The part we know now is the hood. It's the largest flat area as the deck is a hatch with a piece of glass nearly as large as the hood.
I need to do the rest of the car. Should I use the product I still have available or abandon that for some 105? I will do the hood and the rest of the car with the 205 as the final compound step before the polish and wax.
Make sense?
M105 is a compound, M205 is a cleaner/polish. So when you wrote,
Did you mean to write? (not the red part)
Should I use the product I still have available or abandon that for some 105? I will do the hood and the rest of the car with the 105 as the final compound step before the polish and wax.
If you meant the second quote, then again, test till you can hopefully find out which compound is cutting the best and then you should be able to use just that one compound over the entire car to remove sanding marks. You may have to do each section multiple times however to get all the sanding marks out. If you run out of one compound you can always just start using the other compound. By the time you get done with the truck you should have a feel for which compound is cutting the fastest.
After all the compounding is over and all the sanding marks are removed, then re-polish the entire truck with the M205 and then go to wax or paint sealant.
