sqeekykleen
- May 14, 2008
- 199
After wet sanding what compound(s) / pad(s) do you use? Also, do you have to use a rotary, or can you use a cyclo, pc7424, udm, etc.?
Feed back please
Feed back please
You can use a DA, but it will take longer than a rotory. If you use a DA I would use 4" pads for better cut. Do a search on compounds, there's a lot out there, but I perfer the Menzerna line.After wet sanding what compound(s) / pad(s) do you use? Also, do you have to use a rotary, or can you use a cyclo, pc7424, udm, etc.?
Feed back please
:whs: I can be done ,but your arms will be tired!You can use a DA, but it will take longer than a rotory. If you use a DA I would use 4" pads for better cut. Do a search on compounds, there's a lot out there, but I perfer the Menzerna line.
I would use all 3 and maybe Powergloss is the sanding marks are harsh.The Menzerna line is fine, would you use SIP, Nano, 85RD?
