AIO to remove clay bar 'marring'?
sandpaper
I plan on claying my car for the first time with Pinnacle Ultra Poly. I've heard using clay can lead to some marring, which then has to be polished out.
Will Werkstat Acrylic Prime be sufficient to remove any marring I get from the clay? I plan on following that up with Acrylic Jet Trigger.
I have never experienced marring from using a clay bar. Especially Pinnacle Poly Clay. Just use lots of lube and you will be fine. Those products should remove the light marring if any occurs. But it would be best to follow up with a paint cleaner and a sealant or wax if not.
