Not long ago I had to replace the toe cap/cover on my 325xi daily driver. I ordered a new one which came primed. Obviously taking this to a body shop is an expensive proposition so I instead purchased the BMW touch up stick kit and thought I'd give it a go with my airbrush. I thinned out the paint (1:1) and was able to get a nice uniform finish. I followed up with the rattle can clear coat which was too coarse so I ended up doing it over by thinning and spraying the clear coat from the kit. The color obviously isn't a 100% perfect match but it's very close and the uniformity of the finish is excellent.
While detailing my 03' M5 I discovered some rock chips on the lower door panels/rocker panels and have been pondering the idea of using my airbrush to touch up these locations. However, I'm wondering if I should also consider other options like the Dr. Colorchip solution. I've heard about mobile repair techs that have used used airbrushes with seemingly good results but I can't find anyone local who's done this or any videos online.
My main concerns are time involved and quality of the finish. I want the best possible result but the time involved needs to be commensurate to the finished product. Since these are lateral panels using something like the Dr. Colorchip is likely going to require several attempts with light coats to obtain a level finish. The advantage of the airbrush is that the paint dries fast and can multiple layers can be applied relatively quickly but the downside is that you have to carefully mask off the car properly to prevent overspray contamination.
As for the finish, I'm guessing that anything sprayed is going to look better than something that's been dabbed and smeared.
All in all, I figure there are 4 routes I could go:
1) Dr. Colorchip only
2) Dr. Colorchip for base layer to fill in crevasse, followed by airbrush
3) Airbrush only; multiple coats
4) Bondo or putty to fill in the crevasse followed by airbrush
What do you think?
What do you think?
