Airbrush Paint Touch-up---long read
Crazy Amos
Before I get started with this novel I want to thank everyone on this forum for turning me on to the HT pads. I love 'em! Like everyone here said; they cut faster, allow longer working time and actually last longer per pad swap. Like I said before, I have been using CG products pretty much exclusivly but would now like to try M105 & M205. This last car used up the rest of my product and I need to refill. This time I think I will listen to you guys and try them out. Anyway, thanks again-I love this forum!
Ok, with all of that out of the way lets get started. I have a customer who came to me and asked if I could touch up his paint. It was metallic siver and the spots were rather large, rusted and in plain sight. Knowing he loves his car (but just doesn't keep it clean....I do that for him $$) I suggested to let me try a different way to touch it up other than the traditional way. He was a little hesitant at first but when I told him I would do it for free when I seal it for the winter. He had a couple other spots where someone had used a brush or something and it stuck out like a sore thumb (because it was metallic). I reassured him that it would definately look better than that.
Fast forward-------> A couple of weeks ago I submitted an new post titled "Airbrush Touch-up" and was hoping to get some advice on the subject. I would like to thank those of you who showed interest and the advice that was given, but in the end it was very little (by no means am I complaining). So, that led me to believe that there hasn't been anyone that has tried or thought about using an airbrush to touch-up rock chips. Actually I found there wasn't much info on the subject anywhere and thought that a "how-to" type of article may be interesting subject and helpful to many. I hope that we can take the method I used and build on it. Kinda like a think tank.
Please, keep in mind that this is the way I approached it and by no means am I trying to portray myself as an expert on the subject. I would like this to be a learning experience for all of us because we all hate rock chips and/or scratches!!!
The touch up kits that are available definatley work and get the job done, but alot of the times when the affected area is "larger" in size you have to use a brush or a toothpick which usually does not blend very well. Flat colors usually come out OK, but its the metallics and pearls that look horrible. They come out flat and darker than the surrounding paint causing them to almost look worse because it seems like a
half-***ed job.
After a few days of thinking of a way and trying to research for a way to tackle this I finally settled on a method and tested it. After a couple of coats, I thought it was satisfactory and decided to go with. Below is what I did and how it turned out.
Getting to the good stuff.
Equipment and Materials used:
4 gallon 115 psi air compressor with filter and regulator
Air Eraser (miniature sand blaster) with 220 grit
Air Brush
Resperator
Glasses to protect eyes from flying grit
Nitrile Gloves
Q-Tips
Painters Tape
Masking plastic
Microfiber Towels
Laquer Thinner
4 oz of paint mixed to color code
Process - I would do this with pics but dont have a pic for every step (sorry was focusing on the task at hand and forgot)
1. Wash car to remove any dirt on the paint to eliminate the chance of the masking plastic scratching the paint.
2. Dry
3. Tape off accents and trim, then mask off everything around your working area. Do not tape up to the edge of the chip, leave some area open because you can always clean the overspray with a microfiber and laquer thinner. This helps you see how it is building up. If not you may add too much paint while spraying and cant see how the over-all picture looks.
4. Erase the rust. Use the 220 grit and set your regulator to 60 psi. Place the nozzle about 1/8 of an inch away from the spot which keeps the overspray down and allows better control to get right up to the edge of the paint. Be careful not to spray the paint because it will rip right off.
I found that using the air eraser is extremely fast and efficient way to remove ALL of the rust. Since the area is small it is hard to get up to the edge of the paint with sanding pen or paper. Not to mention it only takes about 2-3 seconds....literally.
5. Use the compressor to blow away the left over grit to avoid scratch the paint.
6. Pour some laquer thinner onto a microfiber towel and clean out the chip to remove any dust and allow to dry. It only takes a few seconds, then wipe with a dry microfiber.
7. Shake the paint to mix it, then pour the amount needed into the airbrush bottle.
8. Using a small cup or bowl and pour laquer thinner in and place the Q-tips into the thinner. Fold up a microfiber towel and pour little thinner on it.
9. You are ready to spray. Set your pressure, volume, and distance by spraying on something other than the car. In my case I used the tape and plastic but anything will work. I found that full volume (trigger pulled all the way back) and 18 psi and a distance of about a 1/2 inch worked well.
10. Spray your first spot. Dont worry about the overspray because it is very minimal at such low pressure. If you spray directly into the spot it will create a "splattered" look. Instead, spray using a fanning motion passing back and forth over the spot. Two or three passes should do it per coat.
11. After spraying, take the microfiber with the thinner on it and wipe the surrounding area. Once the general area is clean, use the Q-tip and clean up to the edge of the spot like you were coloring and trying to stay in the lines. Roll the Q-tip as you wipe so that you are always wiping with a clean part of it. Then take the opposite dry side and dry the area you just wiped.
12. Repeat steps 10 & 11 for the remaining spots and coats.
11. Allow to dry and then seal using a wax or sealant of your choice.
Pictures!!!
Pics are from start to finish-I fully detailed this car as well but will post those pics later. It takes me while to upload.
Equipment used minus the air compressor
Before
Before
Before
Before
Before
Air Eraser
Getting ready to blast
After sanding-before spraying
After sanding-before painting
Touch up when using a brush--dark and flat in color
After spraying
After
After
After
Thanks for taking the time to read this and check it out. Its not perfect up close but looks pretty good from a couple feet a way, plus it seals in it and helps prevent rust. I only put a couple coats on because it is very time consuming and my customer was more worried about the rust than anything. You could easily build it up to be flush with the rest of the paint if thats what you want and you have the time. Sorry if the pics are bad, i thought they would turn out better. Again its not perfect...but I still think it looks better than using a brush. For metallics anyway....
Let me know what you think.
I will post the pics of the detail tomorrow. It took me 2 hours to just get this part of the post done. I had to figure out how to put the pics in...had to upload them to photo bucket because my gallery wouldn't work for some reason. Plus I hit the submit button on accident. I got so mad I almost didn't add the pics!
Anyway, until tomorrow...Peace, love and hair grease!
I've often thought about trying this approach. The paint on the front of my wifes Toyota Camry has a couple of "opportunities" to test!
Nice work and than you for the writeup! :props:
Not a problem. I have used alot of good info from here and thought I would try and add to it.
Let us know how the Camry turns out. I am curious as to how a flat color will look.:)
Holy Smokes. This is amazing. I have always wanted to do air-brush ~ touch-ups. Thanks for taking the time to post here. That was super nice of you. Really looks like you know what your talking about for sure :buffing:
great work! I have a couple of spots on my Avalanche that I could use this on. They aren't down to the paint, but down to primer. Good practice! Of course I'd have to get myself a bigger compressor. I have a tiny little one that I use for my finish nailer and pumping up tires. May work but it would be a good excuse to upgrade..
Thanks for taking the time to write up. Great post!
Honestly I didn't read the whole thing so you may have answered this. Why didn't you feather sand the chips so they would no longer stand out as much as they do now?
Thank you for this post. My car's paint is metallic and I have chips on the hood. I have used Dr. Colorchip on my last car (single stage red)and while it worked quite well, I knew that it is tough to "blend" metallics. This process looks like a good way of addressing chips in metallic paint.
Time was pretty much the factor with that-i did it my first couple test runs but it takes a bit longer and adds time to an already time consuming process. The best way to do it would be to feathersand the edges into the pit and then fill to flush but I was already pushing to get it done before he came to pick it up (I was doing a full detail as well). He was more worried with the rusting than the look so I just went with. In the end he was very very happy with it.
Good question by the way and thanks for bringing it up.
I know it is a lot of work re-doing paint and body work. I have done it for years. I also realize that your new to the whole airbrush thing, however how can you paint over chipped paint after removing the rust? By the way, there's rust under the edges of the chipped paint that will bleed through very quickly after being painted. You really need to smooth out the paint, primer, then paint, with some wet sanding in between.
I don't want to be so critical, but I though you should know what to expect.:awman:
Not at all jpatt-this is the reason I posted it. I want to learn as well. Im not claiming to be an expert or anythig I just knew that when I tried to find info on it, there's very little to be found and just thought I would shine some light on the subject. But you are the exact type of person that we all need to hear from on this stuff because this is the first I have attempted anything like this. But after I used the air eraser it didn't look like their was any rust left. I understand the primer part also-although u had a can and tried it this time around it was a pain to wipe off when doing it the way i was trying to.
But again, i an glad you brought this up because I want to know how to do it correctly and I am sure others do as well. Since you are a paint and body guy- how would you have done it? I ask this no intention of being a smart*** I just want some educated knowledge.
Sorry if there are typos and such but I am replying on phone and it doesn't let me scroll through and reread and its very easy to fat finger the keyboard.
Thanks in advance.
Someone once said, "If you don't have enough time to do it right the first time, how are you going to have time to do it over."
I do agree with that but like I said I am not an expert. I did it the way I thought would work-not saying it was right but at the time thought it was a good way to do it. If you would actually read what I wrote in the beginning you would understand this. I posted this to hopefully get a good discussion going and actually fnd out the best and correct way to do it.
My thinking was that if you remove the rust you could paint because that is what is done on any other small chip repair with touch up paint using a brush or toothpick etc. With that said-sorry if it wasn't yhe absolute correct way to do it but I would like to know how of someone is willing to explain.
I'm personally impressed anytime someone tries the unknown... and even more, I appreciate it when others stop what they're doing, grab their camera and take pictures of the process, and then put together a write-up to share what they learned and the results the achieved. The project itself is a lot of work, taking pictures and writing an article is even more time and work.
Thank you.
:bowdown: :bowdown:
Thank you for the props Mike. Hopefully your input has legitimicized (if thats even a word) this post and now we can move forward and LEARN and this will become a "think tank". I know once someone can perfect this type of touch-up we all will benefit from it because I know an airbrush when used correctly has got to be better than a brush, in this application anyway.
This is why I love the AG forum because it seems like their are a number of these posts, and many of them have helped me personally. Quite a few being yours. Everyone here loves to try new products and I don't see why a new method, process or whatever would be any different.
But again, thank you.
JPatt1555 - Now this post does make you sound "critical".
Thanks in advance.
All my man tfullercdi wants is some educated knowledge! So why don't you educate us some more and elaborate on the "smooth out the paint, primer, then paint, with some wet sanding in between" or just keep your no value added comments to yourself!
Thanks for the write up tfullercdi!
Nice write up of your process. Cutting out a hole in a piece of paper and putting it against the surface, like a rock chip template may have simplified the "surrounding area clean up". I plan to do some similar work after the winter, hopefully learning from and contributing to, the methods of the process and this thread. For now it's time to push away from the keyboard, long day tomorrow. :xyxthumbs:
