MarkD51
Active member
- Oct 15, 2012
- 3,130
Hello folks,
I know many of you suggest always using some type of paint cleaner after a final polishing-glazing paint correction process, and before any LSP is applied, to assure proper bonding results.
But I have thought about Iso alcohols, and recently I mixed up a small solution of 15% alcohol-distilled water mixture, and now remember this alcohol I used was the 70% variety, often referred to as "Rubbing Alcohol".
Now I'm no chemist, but I seem to remember that with 70% Rubbing Alcohol, the other 30% is not just water, that there are other products added (A linament or such?). And the products that are added might hinder rhe cleaning properties.
I'm assuming this is not optimal, that I should be doing a mix from a purer 91% alcohol instead?
What's your thoughts on this?
Thanks, Mark
Thanks, Mark
