All purpose cleaner
Megs APC+. Works quite well and is low cost. There may be better, but the Megs is good stuff.
Sparty
Optimum Power Clean is my favorite and can be used from engines to leather and paints SAFELY! It is a bit pricy but worth it's weight in gold. Megs APC+ is also a great choice and a bit more cost effective but I would caution which surfaces it may or may not be safe on unlike OPC.
I use both APC+ and OPC. Both work VERY well. As stated above APC+ is definitely more cost effective. I use APC+ on everything but leather and paint. For leather I use a dedicated leather cleaner, and for paint I use P21S TAW or OPC.
APC+ is my go to. 1:10 on most interior surfaces. 1:15 on leather, and 1:4 for the really tuff carpet stain. For $15/gallon you can't go wrong.
+4 --- Even have the wife hooked on it for in-house cleaning. Hopefully this gets her away from getting a library of other cleaners she purchases.
OPC in different dilutions for tires, paint, and interiors.
OPC is the best All purpose Cleaner and yes, it is more expensive. I know that when I grab my spray bottle or put in my wash bucket i'm not going to damage anything, unlike apc+(just my personal experience).
Meg's APC and APC+ are my two go to APC products. My wife also loves them for cleaning projects around the house. She has taken over my supply of APC bottles and the D-line Glass Cleaner too. I really have to get some more spray bottles so I don't have to go looking for them all the time, LOL.
FWIW, the APC+ does a bang up job of cleaning stainless steel appliances according to the boss.
Cleans BBQ grills with ease... :props:
Another vote for APC+ and OPC. My preference is OPC because I can safely use it on any surface. APC+ plus might also be safe on leather but they don't recommend it. For most cleaning, you can't go wrong with either.
OPC wins!
Here are a few helpful links to purchase.
DILUTE IT!
I've been using 10/1 for most cleaning and it's tough enough to cut almost anything.
Optimum Power Clean All Purpose Cleaner 17 oz. New & Improved!
Optimum Power Clean™ All Purpose Cleaner 128 oz. Refill New & Improved!
I am sticking with letherique Prestine Clean for leather cleaning.
as for vinyl or dash, i'm sticking with 303 Aerospace Protectant unless there is something sticky, or just well beyond normal dirt. then the OPC comes out to play.
hope it helps!
chris<pixelmonkey>:D
Huh?
D101 APC:
The superior foaming action gently lifts the dirt away while its unique blend of fabric softeners and optical brighteners enhance the look and feel of carpet, upholstery, vinyl and even leather.
D103 APC+:
Meguiars All Purpose Cleaner Plus D103 removes dirt from fabric, carpet, upholstery, vinyl, rubber, leather, and so much more. The low foaming formula lifts dirt and grime out of floor mats, but is gentle enough to safely clean leather.
I've used APC on extremely dirty leather with great results. I prefer the D101 product as it generates a lot more foam and thereby doesn't over wet leather. Not my everyday leather cleaner but when I run up against really neglected leather I use D101 and don't worry about it causing harm. I do test for colorfastness though but have never come across any problem with leather over years of use.
Where did you hear that Meguiar's doesn't recommend it? The quotes I posted come from the labels on their respective jugs.
I use Meguiar's All Purpose Cleaner Plus. Dilute it 4:1 for tires and wheel wells and even carpets. 10:1 for very dirty leather, 20:1 for light cleaning.
As mentioned, Optimum Power Clean is another fantastic product.
Huh?
D101 APC:
D103 APC+:
Senior moment. I'm not sure what product I was thinking about. Sorry for the misstatement. In fact I have used APC+ on leather.
I use Meguiars APC+ as my go-to cleaner because of its price. But I LOVE Optimum Power clean. Its just more expensive. If your only using it on your own cars I would go with OPC. But if your going to use it a lot I would go with APC+
Sent from my DROID Pro using Tapatalk
No need to apologize for senior moments as no one has more of those then me, ;) Just wanted to correct the record or find out some new info on APC/APC+
D101 is good stuff too, but the smell is horrible and it makes me cough.. D103 does not do that to me for some reason.
