Alternative to Brinkmann Swirl Finder Light?
mcpp66
I can't seem to find this anywhere anymore so I need a recommendation for some alternatives. I bought the light from Flex from Autogeek a little while back and I think it's okay, but I don't like it as much as I liked the Brinkmann. Which flashlight do you guys use to find swirls?
There are several swirlfinder lights avaialble on the market. I got the Scangrip pen light and it works really well. Sonax and Rupes make one as well. Scangrip also make higher light output products.
If you want top quality, the SCANGRIP can't be beat.
I typed the below into Google and brought up the following articles, nothing on Facebook? Guess Google doesn't serach and index Facebook? I've posted most of the below to my FB page?
scangrip sunmatch mike Phillips
Why you want a SCANGRIP Sunmatch Swirl Finder Light - Initial Inspection, Final Inspection and everything in-between!
SCANGRIP Sunmatch - Showing Wet Sanding Scratches and Holograms
SCANGRIP Sunmatch Swirl Finder Light - Product Review by Mike Phillips
Interior Detailing - 2 Tips and 2 Tools - SCANGRIP I-View and Tornador ZV-240 Velocity Vac Dry by Mike Phillips
SCANGRIP TV COMMERCIAL - SCANGRIP Swirl Finder Lights - Review with pictures by Mike Phillips
Review: SCANGRIP Matchpen Swirl Finder Light - Intense Swirl Exposer in a compact size by Mike Phillips
Then there's this one,
All my SCANGRIP Swirl Finder Light articles in one place - Mike Phillips
This is not an article on the SCANGRIP Sunmatch Swirl Finder Light but it does have a LOT of pictures that show what this little sucker can do...
Pictures: 1947 Lincoln Zephyr Coupe - Show Car Makeover at Autogeek!
And on Innovative Tools & Technologies, INC. website....
Mike Phillips Loves the ScanGrip LED Detailing Light!
Scangrip Sunmatch to Make TV Debut!
Mike Phillips’ Scangrip Commercial Shoot!
And when the frame cracked in my 1987 Chevy Silverado I used the SCANGRIP Sunmatch light with it's magnetic base to light up things like bellhousing bolts when I removed the motor, transmission to get to the inside of the frame, clean everything up, get the crack repaired and the install the HD frame brace to prevent it from happening again in the future.
Awesome light - top notch quality - won't let you down.
Have you compared the Scangrip Sunmatch light with the new version Scangrip Sunmatch II yet Mike Phillips?
/Tony
I have the Rupes penlight and the scangrip. As far as I can tell the two are identical.
